![]() Join Date: Jan 2003
problem with front camber at alignment shop
hey guys
i went to the alignment shop today to change my camber in the front and they said the passgenger side maxed out at -.97 degrees and the drivers side was -2.28. i see the camberplates maxed out all the way and theyre different from one another. could i have switched the coilovers around? would it matter which ones left or right?
1990 s13 IslandMotorsports, Inc. |
would jacking up the car from the radiator support mess it up?? cause i usually jack my car up from there. thanks
![]() Join Date: May 2003
I would bet the spindle bolt will allow some movement...when you put the coilovers on, I bet one loaded up negative, the other positive.
Loosen both spindle bolts, push IN on the coilover, and I'll bet the spindle/hub will tilt toward the negative. Or you have a bent LCA...? - Brian
www.KA24DEvelopment.com |
from Canada, eh!
![]() Join Date: Sep 2001
I agree. I also think the problem is with the spindle that bolts up to the shocks.
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
can someone tell me where the spindle is located exactly? im trying to look it up on google. thanks guys.
from Canada, eh!
your shocks are bolted to the hub spindles. Your shocks are most probably slotted. loosen them up, push the shocks, and look at the negative camber grow!
#14 |
alrite i checked it out today and loosened the spindle bolts and boom! negative camber. thanks for the help guys!
#16 |
from Canada, eh!
Indeed. I can't believe your alignment shop could not see that.
#17 |
it was firestone.
#18 |
AFC #1
![]() Join Date: Oct 2003
I goto Firestone all the time with my Lifetime alingment. I can have the guy put it to whatever I want. He put it to factory. Then I just go back everytime I want to change something. I may have to go back a couple of times cause they are only bugeted like 30mins for the alignment and ajusting mutiple arms can take some time.
