Old 02-02-2005, 10:07 PM   #1
Kyo Kusanagi
Kyo Kusanagi's Avatar
Kyo Kusanagi is a well-known jackass
Send a message via AIM to Kyo Kusanagi
Code 55/Clutch
Okay so i did my CEL code today on my 95 240. The code showed up to be 55 and 55 so happens to be *55 - Normal engine management system operation is indicated – this means all is OK.
My question is if its normal and it means all is Okay, then why did the code show up in the first place? I didn't read it wrong, i did it over and over just to make sure and it was code 55.
Also is my clutch going out on me? Because its pretty hard for me to go into first and reverse when i'm neutral or dead stop.
Kyo Kusanagi is offline   Reply With Quote
Old 02-02-2005, 10:36 PM   #2
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
you might wanna check to make sure you have fluid in the master cylinder, mine was doing the same thing, added fluid and it's good to go...
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 02-03-2005, 06:54 AM   #3
mrmephistopheles
mrmephistopheles's Avatar
55 means everytrhing is ok
*five by five*
Yeah, sounds like your clutch could be fux0r3d. Check your master and slave cyls first.
Originally Posted by PHLIP
Old 02-03-2005, 10:31 AM   #4
Kyo Kusanagi
Yeah, this morning i started it up again but this time, i coudln't put it in any gear. Its really really hard, i had to like kinda force it a bit. When I poped in reverse the car just moves backwards itself without me mixing the gas.
I can only go into reverse but first is a pain in the ass. If i do need a clutch, what kind do you guys recommend? When I had my integra, I got the ACT 4 puck which was good enough for me, or is Nissan different?
Oh I also forgot, when i revved it when it was in neutral, the check engine light came on for every single RPM. When it dropped back to neutral the light disappears....????
Old 02-03-2005, 08:40 PM   #5
Phlip
Yes, I look like that
Phlip's Avatar
Personal preference, stock KA (or even with minor bolt ons) is the ACT, skip the pucks and all that other shit
Weirdo
And I write too!
