Old 06-28-2004, 11:32 AM   #1
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
5K fuel cutoff on KA??
I was at DD17 over the weekend and doing 3rd gear drifts, then downshifting into 2nd then the stupid fuel cuts off at 5K
for some strange reason i cant rev past 5K rpms on my 95 KA24DE...
I'm not sure what it can be, but the Fuel filter is a brand new Z32 one, Fuel pump looks fine (not sure though), new spark plugs/wires, clean Maf/sensor, etc....
would unplugging the 5th gear speed sensor correct this?
Heartwork is offline   Reply With Quote
Old 06-28-2004, 11:40 AM   #2
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
ka doesn't have a fuel cut at 5k.
andrave is offline   Reply With Quote
Old 06-28-2004, 12:24 PM   #3
Heartwork
Heartwork's Avatar
well mine does, no power after 5K, cant rev past 5K....
Old 06-28-2004, 12:44 PM   #4
orion::S14
orion::S14's Avatar
Check for a bad 5th gear switch.
The speed limiter is set for 5000rpm in 5th, so if you have a bad switch, the ECU thinks you're in 5th all the time, and you cannot rev over 5k.
- Brian
Old 06-28-2004, 07:15 PM   #5
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
yea mines doing the same thing, its not fuel shutoff though its ignition.... and im gonna check the sensors..... can i just unplug them or will that mess stuff up? cause i know one of the connectors is messed up and id rather not have a limiter anyway. so will this work?
INeedNewTires is offline   Reply With Quote
Old 06-28-2004, 09:13 PM   #6
mrmephistopheles
mrmephistopheles's Avatar
orion's got it.
the only 5k rpm cutoff is for 5th gear (so you can't go over 110mph).
best thing to do is disconnect the switch entirely.
Old 01-02-2005, 06:56 AM   #7
sleep
sleep's Avatar
sleep is an unknown quantity at this point
Send a message via AIM to sleep
I just completed the 5 speed swap. Only sensor hooked up is my speed sensor. The other 4 are open. Just started my car this morning to drive home and i cannot rev past 5200 in any gear. Its acting like it thinks im in 5th at all times. the sensor isn't hooked up so WTF?
sleep is offline   Reply With Quote
Old 01-02-2005, 07:54 AM   #8
mrmephistopheles
your wiring is probably wrong.
Originally Posted by PHLIP
Old 01-02-2005, 11:11 AM   #9
mr_240sx
mr_240sx's Avatar
- Brian
i had the same problem with my ka24e but now that i got the sr20det i dont have that problem anymore except for the 5K shut off in 5th gear which i would like to know how to remove it!
mr_240sx is offline   Reply With Quote
Old 01-02-2005, 11:55 AM   #10
sleep
sleep's Avatar
how is my wiring wrong? i didnt do any wiring except for the speed sensor. Not yet atleast
Old 02-05-2005, 12:30 AM   #11
boost infested
boost infested's Avatar
boost infested is on a distinguished road
Hey buddy, where is my harness? i paid you back in October of 04. i pm'd you a bunch of times and emails. NO F'ING REPLY!
sorry for jacking this thread.
INSTAGRAM@boostinfested
http://zilvia.net/f/showthread.php?t=569294
boost infested is offline   Reply With Quote
Old 02-05-2005, 12:44 AM   #12
Phlip
Yes, I look like that
Phlip's Avatar
If I am not mistaken, it is the rearmost sensor on the tranny, make that one go away and you cure the problem
Weirdo
And I write too!
