![]() Join Date: Sep 2004
![]() When I drive at about 80mph and i step on my brake pedal harder, my car begins to shake... so weird... really don't know why. recently i have changed the front and rear brake pads, and then the problem exists... thanks for any help or suggestion!
~小アレンのリベリオン~ いくせ, 勝負た! 轟こう, オレのKRMS13!!! オレの得意技!蹴り進入!角度の少ないドリフト! ![]() |
![]() Join Date: Aug 2004
Have u looked at ur rotors? They might be warped. Some people also find that they get alot of brake shimmy when the tension rods are worn. Check both of those two problems.
I'll take 100 to 1 on rotors. Either have them machined or replaced. Go Drilled if you do replace them this will keep you from overheating them again.
Saving Penny's For a real Car Hopefully one will find it's way into my life ![]() |
#11 | |
![]() Join Date: Feb 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
THE ROTORS ARE NOT WARPED, ITS THICKNESS VARIATION. This has got to be the most misunderstood automotive problem. A floating caliper assembly will cancel out that but the thickness variation it will not. A solid rotor will be the best, cross-drilled and slotted are mostly for looks in my opinion. The more mass you have the better the heat can be dissipated.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
#15 | |
#16 | |
#19 |
From wheel bearing runout you get a low brake pedal...
#20 | |
![]() Join Date: Jan 2005
WOOHOOO someone else knows what they are talking about!!! A word on slotted/etc. For the most part yes, high quality blanks(Brembo blanks will really do it for just about everything a street car will see) are the best for braking with street pads most contact area. On pads with no gas output(anything suitable for street use) slots/holes are useless. Drill holes all these really do is increase a rotors tendency to crack, until you get into really high grade materials(See also Porsche brakes) then it's a different story. Slotted are really the best of both worlds, still get maximized contact area, you can slap on a set of track pads and they will work great because the gasses are getting vented, and best of all they look pretty behind big useless rims ![]() If you want to know alot more about brakes go to the Brembo website and read the FAQ wait till you get to the part about warped rotors woo would have thought the pads were depositing uneven? |
#22 |
yes, that's what i think also... i think my alignment got some problems because i have not checked it for a long time already... i hope that's the reason...
#23 |
WOW addicted
![]() Join Date: Dec 2001
actually cheaper street pads are the ones that tend to outgas these days. Quality track pads like cobalt, or carbotech don't have this problem.
and even Porsche's 'drilled' rotors crack at the holes.
#24 |
![]() Join Date: May 2002
I'd hate to crack one of those bling ceramic rotors. The regular metal Porsche drilled rotors can crack, the race cars don't run drilled (usually).
I'd only run a slotted rotor if the car had a problem with water buildup on the brakes. My GTI VR6 had this issue, my 240SXs and other Japanese cars never did for whatever reason. When I'd drive home in the rain on the interstate, I had to lightly pulse the brakes once or twice before I actually wanted to stop to dry the brakes off. This never happened in traffic or at low speeds, only when I'd been cruising at 65+mph for 5 miles or so. Slotted rotors would wick that water away immediately. I think it's just because that car's brakes were so damned BIG - something to think about for those of you with GT-R brakes or similar... |
#26 | |
#29 |
Alignment will not cause a shake or shimmy. How does changine toe, camber, caster and making a car drive straight fix a shimmy or shake. It is a pulsation in the pedal when braking, almost like ABS but without the "cool" sound. That is thickness variation and it is a large problem with Disk brakes.
On a FWD car I would not reccomend turning the rotors just replace. There is a lot of components up front and you want all the mass you can get out of the rotor. If you drive your car hard I would not suggest turning the rotors, just replace. Trust me it is worth it.
#30 |
I have a question guys, I'm experiencing the same problems and I want to change my discs but I have a 200SX which is the same as the 240SX only that mine is european and has a CA18DET. I live in the caribean and the US is the easiest for me to order parts. Will the 240SX discs fit and brake pads??
