Old 02-16-2005, 03:47 PM   #1
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
Tire Stretching Question (when you reverse it)
ive got a 235/40/17 on a 9" wide wheel... if i swap it to a 8" wide wheel, will i gain some height from unstretching the tire? i would imagine so, but im not sure... heres the story:
i bought a set of Nismo LM GT2's, and they have good 235/40/17s on back, but the front has shot up 215/40/17's. now, id like to run a 255/40/17 on back and just move the 235's up front. i test fitted the wheels on the car as is, and the front is just TOO low, and there is alot of fender gap. i cant get any lower b/c the lip would be literally touching the ground. so, the 235 up front will gain some clearence, im just wondering if ill gain even more from unstreching the tire (i hope so). thanks....
Ken
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 02-16-2005, 04:02 PM   #2
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
http://www.zilvia.net/f/showthread.php?t=63466
rancid240 is offline   Reply With Quote
Old 02-16-2005, 07:01 PM   #3
hurleyboi514
ive seen that, its intresting thanks... so am i right? if i put a 235 on a 8 instead of a 9 it should get a little higher??
Old 02-16-2005, 07:02 PM   #4
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
yes it will be a slight bit higher...not substantially by any means though
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 02-16-2005, 07:05 PM   #5
hurleyboi514
bah, alright... cool. i may just have to get a full set of tires. that 40 series is just waaay to small, even with a 235.
Old 02-16-2005, 07:39 PM   #6
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Definitely do something about that 35/45 series junk. Its trashy. Glad to see someone actually putting the proper tire sizes on their rims!
wootwoot is offline   Reply With Quote
Old 02-16-2005, 07:44 PM   #7
hurleyboi514
yah, ideally id run a 235/45/17 up front, and a 255/40/17 in back. we'll see though...
Old 02-16-2005, 07:47 PM   #8
Dousan_PG
Dousan_PG's Avatar
235/40/17 i hope you mean
235/45 is TALL
Aaron
Pink GodziRa
Old 02-16-2005, 07:54 PM   #9
orion::S14
orion::S14's Avatar
Stock 205/55-16 = 24.9" diameter...
235/45-17 = 25.3" diameter
255/40-17 = 25.0" diameter
I just switched from 245/40-17 on all 4 to 235/45-17 F and 255/40-17 R...no fitment or clearance issues with 17X9, +25 on all 4. They are clearly taller, but it's not so noticeable when driving.
- Brian
www.KA24DEvelopment.com
Old 02-16-2005, 08:15 PM   #10
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
wtf are you guys runnin 40's on a fuggin 17 for anyhow?put some MEAT to absorb some shock, man. ya can't grab the road if you're bouncing off of it.
MakotoS13 is offline   Reply With Quote
Old 02-16-2005, 08:56 PM   #11
Dousan_PG
Dousan_PG's Avatar
clearance issues
you cant run a wide tire and a relatively low offset wheel and still clear everything up front, espeically with a higher then stock caster setting.
Aaron
Pink GodziRa
Old 02-17-2005, 04:30 AM   #12
HaLo
from Canada, eh!
HaLo's Avatar
245/40 on a 17" is the closest to the stock ratio, that is why we're using 40 series tires on 17s..
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 02-17-2005, 05:15 AM   #13
hurleyboi514
i just ordered a full set of tires instead... 235/45/17, and 255/40/17. should fit perfect, i used the cacluator to get the sizes, and they are exactly the same sizes as what i was using prior to this (205/55/16). any smaller than that, and id have to lower the car to fill the fenders which i cant do b/c the lip is already too low... ill let ya know how it goes monday...
Old 02-17-2005, 10:29 AM   #14
michael1284
michael1284 is an unknown quantity at this point
wheres this calculator you speak of :P
michael1284 is offline   Reply With Quote
Old 02-17-2005, 10:33 AM   #15
michael1284
n/m google > ME
Old 02-17-2005, 01:36 PM   #16
rancid240
Trader Rating: (72)
Hmm...But now you will have a taller tire up front...by a smidge, but I wonder if it will be noticeable. I was stuck in the same situation starting with a 205/55/16 and decided just to go 225/45 all the way around on a 9"...I do have a spare set of 255/40s though and might throw those on the rear.
