Old 03-23-2002, 05:52 AM   #1
silvia240
silvia240's Avatar
silvia240 is an unknown quantity at this point
i have a 95se and why is it harder to do the back brakes.... whats the difference.
at least that is what i heard.... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'>
silvia240 is offline   Reply With Quote
Old 03-25-2002, 12:34 AM   #2
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
If they're the same as the S13's...which they should be...it's a piece of cake. The only thing that might be hard is getting the pads to go into the spring-clips. The trick here is to slide the the pad in perpendicular to the way they're supposed to go, and then rotate them 1/4 turn into position. Also, you can't compress the piston with a C-clamp; you have to get a special tool (pliers will do just fine) and rotate clockwise (righty-tighty) until they fit over the new pads. &nbsp;Should take you fifteen, twenty minutes tops if you have any idea what you're doing.
LanceS13 is offline   Reply With Quote
Old 03-25-2002, 09:02 AM   #3
samiam
samiam is an unknown quantity at this point
Send a message via Yahoo to samiam
Yep, that's about it. The 'hard' part that everyone always talks aobut is that you will have to rotate the piston in the caliper until you have enough room to slip the pads on. That's it, not that hard; unless you have a frozen 'dead' caliper like I did......That sucked!
BuRn DuSt, EaT My RuBbeR !!
samiam is offline   Reply With Quote
Old 03-25-2002, 09:45 AM   #4
will
will is an unknown quantity at this point
yea, i started replacing my rear pads and was a little confused on the piston, it wouldn't go back in and i was like WTF!!??!! &nbsp;should've read my manual better, you have to turn it like everyone keeps saying <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'>
-will
Honda's are like tampons, every pussy needs one
91-S13 coupe
S13koop.net coming soon...
will is offline   Reply With Quote
