Old 02-23-2005, 05:39 PM   #1
epoxy_nc
epoxy_nc is an unknown quantity at this point
cam install (stock)
i cant get the cams to rest perfect against the journals.. (think that's the right terminology...)
aren't they supposed to rest in there kind of snug?
thanks..
epoxy
sr20det powered '93 coupe se
epoxy_nc is offline   Reply With Quote
Old 02-23-2005, 11:36 PM   #2
noodl35
noodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura about
Send a message via AIM to noodl35
it should rest but for them to rest snug requires for them to be bolted down by the brackets first. I just aligned the exhaust cam dot about 12 degrees and the intake cam dot around 11 degrees. Put cam brackets on, handtighten in the order the FSM says to do. THen the cams will seat themselves.
noodl35 is offline   Reply With Quote
