Old 10-21-2004, 01:23 PM   #1
Silver240x
Silver240x is an unknown quantity at this point
Send a message via AIM to Silver240x Send a message via MSN to Silver240x
turbo coolant line
the turbo coolant line that runs from the back of the motor is cut off and bent and has some type of glue to keep it from leaking. Is this line really necessary to have. any info would be appreiciated.
david
Silver240x is offline
Old 10-21-2004, 02:01 PM   #2
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
what engine is this for??
s13silady is offline
Old 10-21-2004, 06:37 PM   #3
90sr
90sr is an unknown quantity at this point
if this is an sr, yeah it is needed if its the line i think it is, lil black line runnin to the back of the engine off the turbo, its an oil line i believe, so make sure thats on there. good luck .
chris's sr
90sr is offline
Old 10-21-2004, 06:47 PM   #4
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
the line running from the back of the motor that turns into a banjo fitting that connects to the turbo...thats the coolant feed, that is very much necessary if your running stock turbo, the guy who had your motor might have been running with turbo that was only oil cooled
97 240sx esaarr | Current Status: SOLD
statik is offline
Old 10-22-2004, 12:39 AM   #5
Silver240x
its a s13 redtop. i tryed looking where it goes too but i cant seem to find it. I might be blind or something...im pretty sure its the coolant line from the back of the motor. Its a hard coolant line and then theres a smaller hard line that runs towards the turbo but its cut off and sealed off.
Old 10-22-2004, 02:47 PM   #6
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
you do NOT have to have it. the turbo will work fine without it plug the return line on the block and the holes on the turbo.
now for those that are saying you have to have it I say its there for he longevity of the turbo it is NOT essential. there are plenty of turbos running only oil cooled.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline
Old 10-23-2004, 12:08 PM   #7
2forty
2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of
i know many turbos just run oil, but i have read many times that if it is the stock t25/t28, they need coolant lines.
2forty is offline
Old 10-24-2004, 10:48 AM   #8
Steeles
Steeles's Avatar
and Im saying they dont NEED to the turbo will function just fine without them. Hence me saying they are NOT ESSENTIAL. YES its RECOMENDED that you run them for the longevity of the turbo but they are in NO WAY necesary for the turbo to operate correctly.
dont make me repeat myself again.
Steeles is offline
Old 10-24-2004, 10:54 AM   #9
mrmephistopheles
mrmephistopheles's Avatar
most japanese tuners eliminate that line for simplicity's sake. watercooling will make the turbo last a bit longer, but since turbos are easily replaceable and easy to come by here, they don't worry about it.
Just dump them and get a turbo timer.
Originally Posted by PHLIP
mrmephistopheles is offline
Old 03-04-2005, 11:40 PM   #10
rps13_fastback
rps13_fastback's Avatar
rps13_fastback can only hope to improve
Send a message via AIM to rps13_fastback
I'm not running coolant to my s14 sr, it works heh
rps13_fastback is offline
Old 03-05-2005, 05:42 AM   #11
mrmephistopheles
way to bring back a thread to answer a thread that's run it's course.
Old 03-05-2005, 10:30 PM   #12
rps13_fastback
aha way to reply to a thread that was brought back to answer a thread that's run it's course
Old 03-06-2005, 02:52 AM   #13
mrmephistopheles
No, it's 'way to lock a thread for too many useless replies after resurrection'.
