Old 02-28-2005, 09:13 AM   #1
pep240sx
pep240sx is an unknown quantity at this point
bad boost gauge or other?
Last night when Idrove home from a friend's house, I noticed my boost gauge would not show vacuum like it normally does. Even when the car is idling, it registers only zero. the car starts and runs fine, so I know there is at least some vacuum. The boost gauge registers boost fine, so does this mean the boost line is collapsing under vacuum or is it something else?
pep240sx is offline   Reply With Quote
Old 02-28-2005, 08:51 PM   #2
pep240sx
bad boost line
I hooked up my vacupump and read idle vacuum of 18 mm Hg, so I think the problem is in the boost gauge. I can get a reading off of the same line. I wonder what would cause this problem. It still reads boost, just not vacuum
Old 02-28-2005, 09:53 PM   #3
rps13_fastback
rps13_fastback's Avatar
rps13_fastback can only hope to improve
Send a message via AIM to rps13_fastback
i'm willing to put money on it that it's your boost gauge. what kind is it?
rps13_fastback is offline   Reply With Quote
Old 03-01-2005, 11:52 AM   #4
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Mine did that when the line was kinked. Only under boost did it straighten out and read on the gauge.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 03-02-2005, 01:58 PM   #5
pep240sx
Bad Gauge
Yep. It's the gauge. I removed it and hooked my vacuum pump to it and it wouldn't go below 0 psi. Then I noticed I could move the needle around by spinning one of the machine screws that was loose.
Autometer fails again
