Old 10-25-2004, 10:20 PM   #1
Mr. Spool
Mr. Spool is an unknown quantity at this point
crazy, idea, altima engine in 240
is it possible to use an altima engine block in our 240s, they look like they would go in pretty much the same, just would need to change the intake manifold and exhaust manifold, and possibly the oil pan.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline
Old 10-25-2004, 10:28 PM   #2
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
dude its fwd
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline
Old 10-25-2004, 10:29 PM   #3
s13driver
s13driver is an unknown quantity at this point
i've ask the same question like maybe..... 3 years ago ??? don't remember but the answer is No, because of the different location for the engine mount or something like that.. don't really remmember... lol
it is so hard to educate the uneducated.
s13driver is offline
Old 10-25-2004, 10:31 PM   #4
Mr. Spool
thats the other thing that I couldnt figure out, generally nissan makes there engines somewhat universal, kinda like there cars. Ie if your car is an automatic it will take a stick swap like butta.
Maybe I should go out side and see if there are bolt holes for our engine mounts, or if its possible.
96' SE Turbo'd
Old 10-25-2004, 10:45 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
nope. 678910
Originally Posted by PHLIP
mrmephistopheles is offline
Old 10-25-2004, 10:46 PM   #6
Thunderchicken
Thunderchicken is an unknown quantity at this point
Why would you want to do this? Just wondering.
Thunderchicken is offline
Old 10-25-2004, 10:54 PM   #7
FastBack 240
FastBack 240's Avatar
FastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymore
No. Coolant lines are totally dif.
FastBack 240 is offline
Old 10-25-2004, 11:12 PM   #8
rainier
rainier's Avatar
rainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud of
Send a message via AIM to rainier
no it wont work. but if anyone ever finds out how to do it then ill change my mind.
rainier is offline
Old 10-25-2004, 11:20 PM   #9
S14DB
AFC #1
S14DB's Avatar
Nissan FWD and RWD blocks are always different. Alot of the parts are the same but the block will never bolt upto the engine mounts and/or the tranny. With the altima engine it's the engine mounts and the Head is different. The Distributor is mounted on the end of the engine not the side.
S14DB is offline
Old 10-25-2004, 11:41 PM   #10
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
eh, the corolla guys seem to have got real good at putting FWD engines into RWD cars, so its def. doable. I say give it a shot. Get out the digicam, the measuring tape, and the notebook, go to a couple junkyards.. buy an FSM, whatever.
andrave is offline
Old 10-26-2004, 12:57 AM   #11
mrmephistopheles
that's because Toyota and Nissan are different manufacturers.
Old 10-26-2004, 01:48 AM   #12
Andrew Bohan
if you're going to do such a difficult swap, please do it with an engine that's worth it.
Andrew Bohan is offline
Old 10-26-2004, 02:23 AM   #13
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
But that's because they are forced to. If there were rwd 20V 4ag engines they wouldn't go through the hassle of converting a fwd engine to rwd. It's not like rwd KA's are super rare anyways, especially since the Silvia/SR bandwagon is at maximum overdrive............
atom is offline
Old 10-26-2004, 06:37 AM   #14
Mr. Spool
The reason why i was contimplating it, is becouse there are tons of non beat on ultima blocks all over the place, and they carried the ka24de engine into the 2000, so finding a low millage relitively new block is deffinitly possible. But odviously the install would not be worth it even if it was possible to pull off.
96' SE Turbo'd
Old 10-26-2004, 07:45 AM   #15
mrmephistopheles
So? KA's were put into Frontiers until '03, iirc.
Old 10-26-2004, 09:32 AM   #16
97DubTruck
97DubTruck is making a name for him/her self97DubTruck is making a name for him/her self
and xterras until 02. (my friend wanted to put the greddy kit on his dads '02)
97DubTruck is offline
Old 10-26-2004, 10:06 AM   #17
s14srpilot
s14srpilot's Avatar
s14srpilot is an unknown quantity at this point
Send a message via AIM to s14srpilot
Swap in a pulsarGti-R sr20det
s14srpilot is offline
Old 10-26-2004, 10:55 AM   #18
urbanimpakt
urbanimpakt is an unknown quantity at this point
so true.
I say go for it man try the swap if I had the garage and time I would think about it.
400x200pixels limit exceded! lol... i'll shrink it later....
"Shallow Pockets Racing" Going as fast as our shallow pockets will take us!
urbanimpakt is offline
Old 10-26-2004, 12:09 PM   #19
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
wait...... so why is putting an altima ka in a 240 such a "crazy idea"?
oh yea, it's not.
RBS14 is offline
Old 10-26-2004, 07:21 PM   #20
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
Its been done, i use altima heads on my hybrid engines.
deviousKA is offline
Old 10-26-2004, 07:31 PM   #21
mrmephistopheles
i'm talking about the blocks, not the heads.
I've seen SR20VE heads (FWD) used on RWD SRs.
FWD KA or SR blocks were not designed to be interchangable. TOO MUCH is different.
People need to stop citing Toyota motors because it's apples and oranges. That's like comparing the food served to the US Army and the Iraqi Army. Same meal being served to same type of people - TOTALLY different stuff.
4AGs swap over WAY more easily because 4AG blocks were designed independent of chassis necessity.
Old 10-26-2004, 07:39 PM   #22
S14DB
AFC #1
S14DB's Avatar
Yeah it's easy to do. Just drill and tap new engine mounting points. Then move to the bell housing...
S14DB is offline
Old 10-26-2004, 11:56 PM   #23
HyperTek
why? does the altima engine make more hp?
Keep it Classy
HyperTek is offline
Old 10-27-2004, 06:03 AM   #24
Mr. Spool
yeah what would the different head do?
96' SE Turbo'd
Old 03-04-2005, 03:26 PM   #25
AZiaNDriftRaceRX
AZiaNDriftRaceRX's Avatar
AZiaNDriftRaceRX is an unknown quantity at this point
Send a message via AIM to AZiaNDriftRaceRX Send a message via MSN to AZiaNDriftRaceRX Send a message via Yahoo to AZiaNDriftRaceRX
umm no!
they hav different 20V motors for the 4ag!
my friend got a 20v on his ae86 BUT! its from a ae101 NOT a ae111
[sry ppl..i hang out around alot of toyo ppl! xP]
dude..y not jus get a freakin stock ka24de? its dirt cheap..literally!
y would u want to go through the hassle of using an FF motor??
ahh well...do wut u want..but b prepared for obstacles!
=p
AZiaNDriftRaceRX is offline
Old 03-04-2005, 03:49 PM   #26
S14DB
AFC #1
S14DB's Avatar
Stop posting in old threads NOW!!!
S14DB is offline
