Old 03-04-2005, 12:31 AM   #1
AadosX
AadosX is making a name for him/her selfAadosX is making a name for him/her self
Send a message via AIM to AadosX
Stock KA24DE Randomly Running Rich...
My car has the stock KA24DE in it with and intake, removed emissions crap, and side exit exhaust (no cat, no muffler, nothing).
The exhaust has been on the car for about a month now with no problems. Usually I drive like a woman... shifting by 3k. Well lately I've been driving much more heavily, autocross, drag strip once, etc. Even around on the street I'm known to get on it some times.
Anyways, the other day my car randomly decided to start running rich, or at least it seems. At idle the car shakes but RPM's are the same... almost like a loping from cams. It also shakes more when accelerating. There's a noticable loss of power, and when I get on it, or just take it easy, the exhaust sounds different. If I go WOT and push in clutch to shift it backfires like crazy (more than normal hehe). It did this for about 10 minutes then went back to normal. I drove for another 30 minutes and it started again. This time it continued for a few hours until I stopped driving for the day. Today when I turned the car on it seemed fine for my 2 minute trip down the road... but it was still warming up. A few minutes after that trip I drove some and it was rich again. It was like that the few times I drove all day, but then randomly went back to normal on my way home tonight. I was actually on throttle when it happened too, and there was an obvious bump in power, exhaust note change, and smoothening out of everything.
Any ideas?
Thanks!
John
AadosX is offline   Reply With Quote
Old 03-04-2005, 02:49 AM   #2
idlafie
idlafie's Avatar
The wiring harness & plug leading to your Engine Coolant Temperature sensor may have a bad connection or short in it. Test the harness & plug by wiggling it as the engine is running. If the idle starts to fluctuate as you wiggle the wire, then the harness/plug connector is the source of your problem. You'll have to go to the dealer to get the replacement pins & plug so you can fix the harness/connector. Remember, the ECU takes the signal from the Engine Coolant Temperature sensor to adjust the fuel mixture. A short or bad connection will trick your ECU into thinking that the motor is still cold dumping more fuel into your intake.
Anyhow, hope this helps.
ID
Old 03-04-2005, 01:41 PM   #3
AadosX
Thanks man, I'll look into that. The other things I've thought of are possibly a faulty injector or just bad spark plug.
Thanks again,
John
Old 03-04-2005, 01:47 PM   #4
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
Always check your basics first, Spark plugs, wires, distributor/rotor/cap, oil change, air filter. The reason ur backfiring is becaues either the fuel aint gettin burned up , or theres too much fuel and not enough air for some reason. a little backfiring without a cat is very normal, even a flame once in a while. but, if you say backfiring like crazy i think multiple gunshot like backfires.
speeddreamz is offline   Reply With Quote
Old 03-04-2005, 02:54 PM   #5
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
is of CEL on? maybe ur knock sensor is causing it
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
Old 03-04-2005, 06:05 PM   #6
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Im having similar problems with my sr. It seems like at times its pulling timing. Like all of a sudden, it'll be weak, sounds loud, and full boost is reached at 3000rpms. No cels are thrown, and the connections look good too. If detonation is sensed, how long does the ecu read from the knock fuel/timing maps?
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
