Old 03-17-2005, 06:52 PM   #1
SOUTHSTAR
SOUTHSTAR is an unknown quantity at this point
Ok im saving for coilovers , Help me out with opinions !
I guess ill just save up for some coilovers and get it done all at once.
I did some research and came up with a few brands that i like . If you know anything about anyone of these let me know if they are good or not and also if there are any other brands that i dont list add them on too.
I dont want some crazy stiff setup as this is a daily driver so keep that in mind.
-SPL kts- $1100 I like the inverted shock design and the fact that you can replace all the shocks for $550 instead of rebuilding them.
-TIEN HE (or the new drift ones) - ($ ?)They seem pretty good.
-MEGAN RACING- $900 Looks like a good coilover setup . If you dont know about then heres a big write up http://www.zilvia.net/f/showthread.p...ighlight=megan
-SILK ROADS-$1400 - I have heard they are good.
SOUTHSTAR is offline   Reply With Quote
Old 03-17-2005, 07:35 PM   #2
Var
Var's Avatar
Send a message via AIM to Var
if I were buying coilovers right now, i would go with the silkroads but i'm not sure if they are servicable in the US
Hi
Old 03-17-2005, 07:44 PM   #3
SOUTHSTAR
See that is a factor. I dont like the fact that if a shock blows out i have to buy 4 brand new coilovers. To me that is stupid.
Old 03-17-2005, 08:11 PM   #4
Var
Var's Avatar
you dont have to buy all 4, you can just buy one. or if you buy teins you can send them out for rebuilding. i think tein is fairly trustworthy at this stage in the game but i sill wouldnt want to be the test rat for the new drift coils unless i got them for cheap
Hi
Old 03-17-2005, 08:34 PM   #5
sw20>>s14
sw20>>s14's Avatar
kts or tanabes; good stuff . on your list i would go with the silk roads or the spl
sw20>>s14 is offline   Reply With Quote
Old 03-17-2005, 08:38 PM   #6
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
SPL is hardcore beefy shit. not rebuild and good price.
DJPimpFlex is offline   Reply With Quote
Old 03-18-2005, 12:41 AM   #7
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
I'll do a quick review of my new coils when I get them. GP Sports GR-6.
RBS14 is offline   Reply With Quote
Old 03-18-2005, 01:28 AM   #8
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
Needing a dremel for new coilovers = not cool><. <<---Edit:reference to the megan write up. By the way, as a note, my buddy bought a set of JIC's for his S2k, and it didnt have brackets for the brake lines>< stuff was just dangling...
personally i went to the tein RA's for a few hundred more than the HE's. yes i realize they are a little too stiff for certain applications, but the 10/8 spring rate(compared to the 8/6) sounded better to me. Out of personal experience i like to reduce body roll with spring rather than bar, but thats just me. as far as the ride, 10/8 is a little too hard for some, but ok for me, body roll almost eliminated. ride isnt too rough, but undulations on the freeway at low speeds are somewhat nauseating. On the Hill... thats where its really nice, the low-piston-speed valving is really nice, very balanced for the cars weight. huge elevation changes around switchbacks are a little scary though. In the rain its not that bad, just gotta remember theres no rear squat anymore so throttle gotta come on gentle, and understeering under heavy braking in the rain is much more pronounced.
.02:=My apologies, im bored, and my diff hasnt arrived yet so im rambling.
i always seem to add in my .02, but thats because if u are still reading by this time my opinion seems to matter so ill go on, Every coilover setup i have ever seen in a car is decently/well balanced. whether its 32 way or 3 way adjustable, adjustment range is the same, just more or less clicks.
so honestly what swayed me to the RA's were the pillow ball mounts, basically a shorter setup which reduces wheel droop, helper springs are nice when driving on crappy roads(though still clacky), spring rate(the valving was made for the spring rate that i wanted) and the fact that the front strut tube(dont laugh at my terminology ...the shiny part... hahah) is huge, like 50mm diameter huge. and as we all know our front strut is basically very integral to front suspension geometry(camber and caster affected by the flex of the strut). And not but not least, the fact that they are rebuidable in america, no sending to japan, California RMA department^^.
downsides to RA's is that its a little stiff and bouncy, not edfc compatable, adjuster for front is bottom of tube, and rear adjuster is really long(which sometimes touches the carpet in the back(it misses the access hole).
im pretty sure youll have fun with whatever u choose. Sorry so long winded
ultraDorksGarage is offline   Reply With Quote
Old 03-18-2005, 01:31 AM   #9
Dousan_PG
Dousan_PG's Avatar
Tanabe DD
they fucking rule
awesome coilover. ive tried lots of coilovesr and these are incredible. and 10/8 kg. perfect
well made, great design, very comfy for street yet still firm. each dampen click is a VERY notciable difference (not like tein HE gayness) and just overall....so nice
ive tired kei office (my second choice), m yfriend has the GR=6 on his car, ive tried JIC FLTA2, Tein HE, HKS, havent done SPl yet, maybe on my s13 i will
but the DDs...amazing! love them
Aaron
Pink GodziRa
Old 03-18-2005, 06:41 AM   #10
[email protected]
kuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond repute
Last I checked (~6 months ago), the R series shocks are sent back to Japan for rebuild, and the quote I got for the rebuild is $600 for 4 shocks :/
kuah@splparts.com is offline   Reply With Quote
Old 03-18-2005, 10:32 AM   #11
ultraDorksGarage
that sux, my local shop said they send it to a shop in cali thats 2 blocks from Tein USA, and Tein USA rebuilds everything... I was told all RA's needed to be special Ordered from the motherland, Rebuilding was just shipping to cali and have em rebuilt in 1-2 months.
well its good i know and ill have to check on that, maybe ill save from shipping from HI >> CA, then needing to ship from CA>> Japan ><
Old 03-19-2005, 04:17 PM   #12
SOUTHSTAR
1-2 months to rebuild tien shocks !? ?! !?!?
That is some serious down time. Ok i guess that really makes me lean towards the SPL kts coilovers, you can get new shocks for $550 no downtime.They also sport an inverted shock design just like kei office.
As long as nobody has had any bad experiences with SPL i think its the obvious choice at this point.
Old 03-19-2005, 05:00 PM   #13
ultraDorksGarage
u have to understand i live in hawaii, shipping alone takes a month round trip, so 1-2 months total is normal here, well imo. keep your stock stuff so if u ever do blow one up u can go back and have 0 down time.
inverted design... i think most systems these days are inverted, including teins... someone correct me if im talking out of my a$$ but i think my RA's were inverted.
Old 03-19-2005, 05:06 PM   #14
sr20tom
sr20tom's Avatar
sr20tom is an unknown quantity at this point
s13 Tein HE
I have them on my s13 and they are pretty good. I wrecked a car with them and had to send one out to get rebuilt. 2 weeks later i got it back. If you want i work for a place in NY, and can get you them for $1200. I you want them PM me
sr20tom is offline   Reply With Quote
Old 03-19-2005, 08:12 PM   #15
midnight zenki
midnight zenki's Avatar
midnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfectionmidnight zenki is close to perfection
s14
Go TEIN all the way, I'm running HE's on my S14 and they've done me nothing but good so far, had them for over a year now no issues.
midnight zenki is offline   Reply With Quote
Old 03-20-2005, 12:00 AM   #16
SOUTHSTAR
OK 2 major questions left i guess
1-how much is it to rebuild a tien shock or a whole set?
2-What is the major advantage of the inverted design shocks? To be honest all i know is that kei office does theirs that way so figured it to be better but im not shure why.
Old 03-20-2005, 11:37 PM   #17
SOUTHSTAR
????????????OK 2 major questions left i guess
2-What is the major advantage of the inverted design shocks? To be honest all i know is that kei office does theirs that way so figured it to be better but im not shure why.????????????????????
Old 03-20-2005, 11:45 PM   #18
kilword1
kilword1 is an unknown quantity at this point
Send a message via AIM to kilword1
silkroad....
kilword1 is offline   Reply With Quote
Old 03-23-2005, 04:26 AM   #19
Catalan
Catalan is an unknown quantity at this point
Aren't the Apexi N1 EXV the same as the MR's and can be rebuilt here in the US. The price is for the EXVs are $1,189 shipped at www.hopupracing.com
Catalan is offline   Reply With Quote
Old 03-25-2005, 04:46 AM   #20
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
Yes.
And buy the MR, they are tight.
95zilvia is offline   Reply With Quote
Old 03-25-2005, 11:17 AM   #21
AutoRnD
AutoRnD's Avatar
AutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the rough
Send a message via AIM to AutoRnD
Zeal coilovers OWNZ JOOO =-)
silkroads and gp sports are nice too =)
www.AutoRnD.com
Nardi, Enkei, Stance, AME Master Distributors for USA
Check Out Our Facebook!
AutoRnD is offline   Reply With Quote
