Old 03-30-2005, 01:46 PM   #1
SRaznDRFTR
SRaznDRFTR is an unknown quantity at this point
Send a message via AIM to SRaznDRFTR
SR Flooded??
okay...i juss read on srowners.com that if your engine cranks, sparks and either juss cranks or cathes but doesn't run...then engine could be flooded...so how do i unflood the engine??
Team Shoganai
Vouch Thread -----> Vouches
SRaznDRFTR is offline   Reply With Quote
Old 03-30-2005, 02:40 PM   #2
the head
the head's Avatar
take out the sparkplugs and let it sit over night
if you take the plugs out and they are dry you have a different problem
are you sure you hooked up the fuel lines correctly? and are your injectors actually working?
Old 03-30-2005, 08:34 PM   #3
SRaznDRFTR
SR
i know i hooked the fuel lines up correctly...and how do you test the injectors?...when we'd push start the car...it would start for a lil bit and slowly drop to idle and die...so iono...i have no idea whats going on... ...and if we tried to gas it up before it dies...it doesn't do anything
Team Shoganai
Old 03-31-2005, 03:21 AM   #4
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
if u think car is flooded, pull 1 or 2 injector harnesses, then crank motor, if it was flooded it will sputter/run rougly for a few of seconds
ultraDorksGarage is offline   Reply With Quote
Old 03-31-2005, 08:02 AM   #5
the head
the head's Avatar
best way to test injectors is with a noid light
I agree though that it is flooded since you can get it to run a little i think you are getting fuel
Old 03-31-2005, 12:23 PM   #6
Rusker
Rusker's Avatar
Rusker is on a distinguished road
The timing is correct?
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 03-31-2005, 01:40 PM   #7
xtremsiege2
xtremsiege2 is an unknown quantity at this point
could be your alternator, motor is turning over for a few seconds and then stalling, running off what battery you have left, the bogging or like feeling like only 1/2 the cylinders are moving happened to me
xtremsiege2 is offline   Reply With Quote
Old 03-31-2005, 04:55 PM   #8
90rps13
90rps13 is on a distinguished road
Send a message via AIM to 90rps13 Send a message via MSN to 90rps13 Send a message via Yahoo to 90rps13
If your motor runs for a few seconds then just dies, then it can't be flooded. Probably alternator isn't charging well. Check timing as well and clean your injectors.
90rps13 is offline   Reply With Quote
