Old 03-30-2005, 02:24 PM   #1
s134
s134 is a well-known jackass
i have searched... flame away, i need help!!
i removed my egr... i took the whole unit out plugged the outlet from the MAF, and plugged the .75" pipe coming from just below my manifold on the exhaust. after removing the unit and doing that i plugged the 2 lines in the intake manfiold that ran to the egr, now my car boggs and seems to go on some sort of pussy mode when i give it any more than 1/4 throttle... what did i do wrong!!!??
s134 is offline   Reply With Quote
Old 03-30-2005, 03:56 PM   #2
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
take out EGR==?!?!?! why'd u bother for 1/2hp? i'm no pro, but i'd say check all your vaccume lines again, make sure they are good, sounds like something's wrong w/ the vaccume nonsense. Or u took out the wrong stuff... ! Or that's what happens when there's no EGR =b
240meowth is offline   Reply With Quote
Old 03-30-2005, 06:11 PM   #3
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
missed something!!!!!
just go back and make sure u pluged everythin! from what u described u didnt actually remove the egr, just the emissions shit to the right of the exhaust mani. to remove the egr u gotta take out the 2 bolts from the actually egr on the pass. side intake mani(its a pain w/ motor in the car) then take the only brown colored piece of metal on that side off (egr is bolt to it) and have the hole welded up and put it back on, u know u got the egr when u removed the big pipe goin from the exhaust mani to the pass side intake mani, hope this helps if not sorry bout that. oh yeah u dont have to remve the whole pipe just cut bout 4 in from the exjasut mani and crip the pipe thas what i did!!!! car run great w/ no probs
sil80forme is offline   Reply With Quote
Old 03-30-2005, 07:55 PM   #4
s134
well i ended up putting everything back together and it's stil messin up!!
Old 03-30-2005, 08:34 PM   #5
sil80forme
sil80forme's Avatar
oh thas the easy way out. i would of spent some time on it. but to each there own, well just go over everything, make sure all is coneted, no leaks, run motor and listen very carefully to hissing sounds and if u hear something fix it, if not i dunno what to tell ya
Old 03-30-2005, 08:42 PM   #6
projectRDM
projectRDM's Avatar
Vacuum leak. Check again.
FORMERLY R240NA
Old 04-01-2005, 12:17 PM   #7
s134
problem fixed
Old 04-01-2005, 03:21 PM   #8
SirWarrior
SirWarrior is an unknown quantity at this point
willing to share????
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
