Old 04-06-2005, 11:31 AM   #1
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
T28, T25 coolant line block off?
Who here is running with the coolant lines blocked off to their stock turbos? Its been discussed that longevity is an issue, I'd like to hear from people actually running it. Any reasons why you blocked it off?
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
Old 04-06-2005, 11:36 AM   #2
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
i would not block off the coolant lines..... all the T series must run with the coolant lines... i think somebody ran them with the lines behind the block(?) not sure... check out ka-t.org... and that info will help you out... i know you have a sr... but itll applie to the T series turbo..... good luck...
SR240DET is offline   Reply With Quote
Old 04-06-2005, 12:23 PM   #3
Flybert
I've known people to run them without it because they were using a stainless mani and they are prone to cracking, so it makes it easier to remove the turbo and weld up the mani.
