Old 10-05-2010, 09:02 AM   #1
Jessele
Jessele is an unknown quantity at this point
New swap not cranking over!
chassis: 1995 240sx (auto)
motor: sr20det blacktop
ecu: sr20det 5spd
harnesses: new upper and lower wiring specialities harnesses
history of the motor: pulled the motor out of a running car - so i know the motor is good.
problem: when i try to crank up the motor, all you here is a loud whine from the starter trying to engage the flywheel and thats it. any ideas?
thanks in advance!
Jessele is offline   Reply With Quote
Old 10-05-2010, 09:16 AM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
is the starter turning the motor over? OR is the starter just spinning?
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 10-05-2010, 12:23 PM   #3
Jessele
starter is just spinning. the motor does not move at all. i had the starter check at the autoparts store and it looks like its functioning properly.
Old 10-05-2010, 06:40 PM   #4
SHIFTrl240
SHIFTrl240's Avatar
SHIFTrl240 is an unknown quantity at this point
So the starter is spinning, but the motor is not turning? Are you sure it's the proper fit starter and flywheel?
The only reason for the starter to be turning and the engine is not would be there to be no contact between the starter and the flywheel.
SHIFTrl240 is offline   Reply With Quote
