Old 11-08-2006, 10:37 AM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
How to wire a condenser fan to battery directly?
My aircondition condenser fan stopped working. I checked circuitry and found the line between condenser fan relay and the air conditioner fuse inside driver's seat has no continuity. I don't want to go through changing entire super junction harness or replacing a wire inside the harness. I would like to hard wire this condenser fan to battery like the way SR people would wire their flexilite radiator fan on to the battery.
I would like to know how to do this. Does any one have schematic for this? What kind of relay and wire and switch do I need to get? I am pretty much new to electricals.
jafero is offline   Reply With Quote
Old 11-08-2006, 11:06 AM   #2
trsilvias13
use a relay, Draw power from the battery, use the fuel pump as a trigger. You can even hide the relay in the fuse box (just take out the ac relay if you have no ac) That is what I did.
Old 11-08-2006, 11:25 AM   #3
jafero
Thanks a lot for the reply.
What type of relay should I get? What do you mean by "using fuel pump as a trigger"? I thought I had to install a switch.
Old 11-08-2006, 02:41 PM   #4
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
He means just wire it so it starts up when the fuel pump turns on...so that way the fan turns on when you start the engine. You can just install a switch to (what I did)...but then you have to remember to turn it off and on.
mRclARK1 is offline   Reply With Quote
Old 11-08-2006, 08:56 PM   #5
jafero
mRclARK1, Thanks for the reply. I get the idea. Do you have a simple schematic of how you wired it up? I am a totally new to electricals so I can't understand FSM's schematics.
