Old 04-08-2005, 10:25 AM   #1
HaLo
from Canada, eh!
HaLo's Avatar
Well I'll be damned..
I just test fitted my 245/45R16 on my 16x7+32 Advan wheel... on the front of my S13 with D2 Coilovers... And you know what? No spacers are required... I just got some H&R 15mm spacers just in case and I won't need them... It doesn't even touch the inner fender. I am really surprised..
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 04-08-2005, 10:41 AM   #2
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
thats good to hear! now put a 275 in back...
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 04-08-2005, 12:21 PM   #3
019
019's Avatar
019 is an unknown quantity at this point
Send a message via AIM to 019
really? wow... how much camber are you running? i have some 16x7.5 with 205/55 and they won't fit with my coilovers (not d2). i got some 5mm spacers and they barely clear. oh, the offset is +40 +35 with the spacer, obviously. i've been meaning to get a hold of some 225/50 to see if they'd clear. maybe i'll get lucky then
019 is offline   Reply With Quote
Old 04-08-2005, 12:28 PM   #4
Flybert
Camber has nothing to do with it. Shock bracket length and wheel offset has everything to do with it.
Old 04-09-2005, 07:26 AM   #5
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
my 245/45 clears in the front with my d2s with a 16x7.5 with a 22 offset. Whattaya know, d2's are good at somethin eh? haha
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 04-09-2005, 08:17 AM   #6
98sr20ve
98sr20ve is an unknown quantity at this point
I wonder what that would mean for the Kosie wheels in 16X7.5 same offset. Sometimes I can't seems to wrap my brain around the wheel offset thing once you throw larger wheels in but the same size tire.
98sr20ve is offline   Reply With Quote
Old 04-09-2005, 12:01 PM   #7
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
Hold on to the spacers until you get a chance to race on them. They may rub under load. Of course, spacers may not help with that kind of rubbing.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 04-09-2005, 09:38 PM   #8
HaLo
from Canada, eh!
HaLo's Avatar
I will hold on the spacers just to widen the front track to reduce understeer.
-> HaLo
Old 04-10-2005, 12:30 AM   #9
019
019's Avatar
i beg to differ. when i first put on my coilovers, they were so low that i was running about 4-5* of camber and i rubbed the shit out of my tire. i'm running 2* of camber now and it clears fine. that was on stock 15x6 rims with 205/55's on.
Old 04-10-2005, 05:38 AM   #10
98sr20ve
It depends if you are adjusting camber at the knuckle or the tophat. If you adjust at the knuckle then you can easily gain or loose a lot clearance thru camber adjustment.
Old 04-10-2005, 03:25 PM   #11
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
Why do autocrossers tend to put such huge tires on wheels? A 245 seems more at home on an 8-9" wheel than on a 7". For example, I would think that for a 7 F 8R combo, 225 and 245 would be good healthy tire sizes. Yet I routinely see people go even wider than this. Is there a benefit to cramming so much tire on seeing as grip is mostly a function of compound?
turtl631 is offline   Reply With Quote
Old 04-10-2005, 09:34 PM   #12
ghambino
ghambino will become famous soon enoughghambino will become famous soon enoughghambino will become famous soon enoughghambino will become famous soon enough
I would guess to increase the amount of tire that makes contact with the road, which results in more grip.
ghambino is offline   Reply With Quote
Old 04-10-2005, 10:40 PM   #13
yudalicious
yudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond repute
too bad grip is a function of compound and weight, and bigger tires don't necessarily mean more contact patch, in other words, your answer is wrong.
I am with turtl, I'm also curious why people run such big sizes, is there a benefit that we're not seeing here?
yudalicious is offline   Reply With Quote
Old 04-10-2005, 11:10 PM   #14
HaLo
from Canada, eh!
HaLo's Avatar
It works.
225/245 combo doesn't.
I guess you can't apply some road racing/lapping rules on auto-x.
-> HaLo
Old 04-10-2005, 11:17 PM   #15
Hikarispeed
Hikarispeed's Avatar
Hikarispeed is an unknown quantity at this point
Send a message via AIM to Hikarispeed Send a message via Yahoo to Hikarispeed
Clearance also depends on the specific tire you're running. My ES100's don't have the same shape compared to my Avon's
Well the results from autox in my region tend to give better results to the guys with the wider tire. There are so many variables in there though as you all know.
You can go too big; too much rotational inertia, affects to your suspension, and not being able to get them to optimal tire temperatures... Tires are very hard to analyze so it is difficult to determine the best width. The best way is to test.
I'm running 225's, will go to 245 next season to know how they differ for my setup.
Kaizen Racing
Hikarispeed is offline   Reply With Quote
Old 04-11-2005, 12:49 AM   #16
ghambino
How is that wrong? and stop repeating what we already know. Why do you think people upgrade to a wider tire. If you take a tire that is of the same compound in a 225 and a 245 which do you think will give you better traction. Of course you can go overboard if you put an excessively wide tire that will hinder performance ( for example a 255 tire on a underpowered AE86), thats why you test different sizes to see which one gives you good grip without creating too much tire weight and rotational inertia. Go to an autocross event and look at the rear tires of a porsche 911.
Old 04-11-2005, 12:53 AM   #17
ghambino
Do you get a lof of tire flex with the 245s on a 7inch rim?
Old 04-11-2005, 05:05 AM   #18
jmauld
That argument may hold some truth in the theoretical world. But here in the real world where cars are limited by the width of tire they can run, it really isn't possible to run too wide of a tire.
Jason
'95 240sx SE
Old 04-11-2005, 05:30 AM   #19
hurleyboi514
the tires he's running probably are R compounds which have very little flex...
Old 04-11-2005, 05:38 AM   #20
nlzmo400r
^^this is true, on a street tire, sure, there would be too much shoulder flex, but on ao32's, doubt it
Old 04-11-2005, 07:19 AM   #21
98sr20ve
It works.
So true, Autocrossing has so much more understeer then roadcourse stuff.
Old 04-11-2005, 08:59 AM   #22
HaLo
from Canada, eh!
HaLo's Avatar
Thanks a lot guys for explaining what I could not.
I am running A032R, which are Race tires. I also ordered some Hoosiers and will see what I can do with those.
-> HaLo
Old 04-11-2005, 09:22 AM   #23
yudalicious
It works.
obviously it works seeing how many ppl opt to use this set up, I was just curious on WHY it works, as it seemingly goes against physics
(and ghambino, what you said is still wrong, more patch DOES not mean more grip, think an R compound tire w/ a smaller contact patch vs. Wal mart tire w/ bigger contact patch. AND wider tires DO NOT always mean more total patch area, maybe more "horizontal" patch that helps w/ lateral stability.)
I'm not arguing against you autocrossers that run this set up, obviously there's alot more to it then simple physics, I am just simply wondering why.
Old 04-11-2005, 10:03 AM   #24
Hikarispeed
Compare apples to apples dude. A good book to read is Race Car Vehicle Dynamics by Milliken.
I work on some club racer's cars on weekends from GT3 to FF1600's. They are limited on wheel width, but they cram as much tires on there as possible. These tires are specially made to be so very wide on a skinny 7" rim. Sidewalls are so stiff that if you get a flat, it is hardly noticable statically.
I heard Hoosier's should blow A032R away easily, tell me if it really does.
Kaizen Racing
Old 04-11-2005, 11:26 AM   #25
yudalicious
I am comparing apples to apples, just merely informing ghambino that not only did he NOT answer the question at hand, he missed 2 critical truths of the laws of physics...
with that said, I am not arguing that bigger tires won't give you better times, you guys are the experts here, I am merely asking why they do, even though doing so seemingly goes against physics...
so far 3 people have reaffirmed the fact that most people run as much tire as possbile, but no one has replied why.
Old 04-11-2005, 11:30 AM   #26
yudalicious
so far your post has given the most info on the question, there's probably many variables that come in play, and I do see autocrossers running wider tires alot, just trying to understand the physics behind it.
Old 04-11-2005, 11:45 AM   #27
jmauld
How does it go against physics?
Jason
'95 240sx SE
Old 04-11-2005, 12:02 PM   #28
yudalicious
well, it doesn't really go AGAINST physics to run bigger tires, but since ffriction (grip) between the tire and the surface is based on coefficiient of friction of the tire (compound) and the normal force (weight), contact area doesn't really come into play. My other point is sometimes, running wider/taller tires does not always increase TOTAL contact patch.
Now we all know that's only part of the game, as obviously wider tires DO do better, and so far I've only found 2 possible explanations:
1. the wider tire offers more horizontal/lateral patch
2. better heat dissipation
I'm merely looking for some more explanations, it'd be nice if I could know why doing something helps.
Old 04-11-2005, 05:30 PM   #29
Rennen
Rennen's Avatar
Rennen will become famous soon enoughRennen will become famous soon enoughRennen will become famous soon enough
This isn't a classroom block drawn on a chalkboard, its a tire. And tires are deformable, tires also get much of their force from getting in-between particles of concrete and creating non-normal forces. If you are a running a wider tire, you can run at a lower pressure because the cars weight is spread out over a larger contact patch, this lower pressure allows the tire to deform more, and create more forces.
Let me see if the intranets has anything useful...
BINGO!: http://hyperphysics.phy-astr.gsu.edu...rict3.html#are
Then click the "coefficient of friction" in the last paragraph.
So there you go, those tricky physicists are making assumptions that aren't quite valid for autoracing.... or you can just tell all your friends that your car defies physics.
-Matt
'89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut
'95 BMW 540i 6 speed: Ultimate Commuting Machine
PFM Racing
www.solo2.org
www.midwest240sx.com
Rennen is offline   Reply With Quote
Old 04-11-2005, 05:32 PM   #30
yudalicious
I did some research and came up with this:
http://forums.bimmerforums.com/forum...d.php?t=328261
Quick summary:
"For anyone who liked the "wider tires aren't any faster" debate...
I would suggest running out to Barnes and Noble and picking up the March issue of Racecar engineering. The very last article in the mag (last 2 pages actually) deals with this exact topic. The author admits that everyone 'knows' that wider tires are faster, but also that, scientifically speaking, they really shouldn't be. That is a huge and horrible oversimplification, but in case anyone was looking for a definitive answer I want them to know this isn't it. What is in this article is a couple of theorys as to why wider tires appear to be faster and also a quick explanation of why they shouldn't be. There is also supposed to be a second article in the series in the next issue so keep an eye out for that as well.
I'm not trying to start the whole debate again, but the article was a good summary of the whole tire paradox and at least one of the why-wider-is-better theorys was something I'd never heard mentioned before. Anyway, just go read it, it's quick and interesting."
And, this from a guy who read the article and summed it up:
"Here's a brief synopsis though. (of my posts, or the article...? hard to tell... )
- Columb's law for friction
- Tires contact patch area does not vary with its width.
- Tire width, construction, and inflation pressure change the contact patch shape, not size.
- If we take a narrow tire and make it wider, the contact patch stays the same size, but gets wider and shorter.
- A wider tire has a greater surface area in contact with air to surface area in contact with the ground ratio.
- Wider footprints (contact patch shape) have smaller region of acceptable slip angles that are within the grip zone of the tire."
Basically I think this is very interesting, as it seems zilvia.net isn't the only forum having trouble to explain WHY wider tires are faster, hope this helps.
