Old 04-22-2005, 06:21 PM   #1
bcrume
bcrume is a well-known jackass
Metal shavings in the oil pan
I just got a clip and I dropped the oil pan to bang out a small dent, there are metal shavings in the bottom of the pan. I'ts not alot of shavings but is that normal? -s13 redtop-
bcrume is offline   Reply With Quote
Old 04-22-2005, 07:09 PM   #2
TheTicTac
TheTicTac's Avatar
TheTicTac is a well-known jackass
shavings or grains? A certain amount of metal will be in the pan, happens during cold starts. So unless it is large shavings, you shouldn't have to worry to much.
*GorgeousGarage* L.oose S.ocks D.aisuke !
TheTicTac is offline   Reply With Quote
Old 04-22-2005, 07:23 PM   #3
lucky7
if you still have the oil filter that came w/ the clip, i would slice it open to see if there are shavings in the filter. that would atleast tell you if it was a recent problem.
Old 04-22-2005, 07:43 PM   #4
bcrume
I'll go slice up the filter right now
Old 04-22-2005, 09:33 PM   #5
bcrume
the filter is on ther so tight, I was gonna pull it out tomorrow so I'll just check the filter then.
