Old 05-01-2005, 01:34 PM   #1
neverdone
neverdone is an unknown quantity at this point
toe question
I know that the toe arms on the rear of a s13 are adjustable, but at what amount of droppage do you surpass the stock adjustablity and have to buy new toe arms?
neverdone is offline   Reply With Quote
Old 05-01-2005, 02:09 PM   #2
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
If your car is dropped to a point where it looks good, then you have gone beyond the stock bolts adj possibilitys.
Anything lowered more than 1.5 inches or so
remember.
0 toe in the rear
1/4'' toe out in the front
blu808 is offline   Reply With Quote
Old 05-01-2005, 02:11 PM   #3
Dousan_PG
Dousan_PG's Avatar
toe in in rear
more stability and grip
but those settings are all preference haha
not one of those threads
what blue 808 said
also makes the car more solid feel. less slop and changing.and you get that PRECISE adjustablity which can be hard to get at times w/ eccentric bolts.
Aaron
Pink GodziRa
Old 05-01-2005, 04:04 PM   #4
S14DB
AFC #1
S14DB's Avatar
I've had my S14 down to 2" and still had 0 toe on stock rods.
Old 05-01-2005, 04:37 PM   #5
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
Toe and camber are not really adjustable seperately with stock parts. They are.. but read on...
What I mean is, you can drop it a bunch and still get your toe settings right as long as you're OK with running tons of camber. And vice-versa, you can only get your camber back to about 0 if you are willing to run major toe-out. There is of course a limit where you wont get factory settings back no matter what you do.. but you'd have to be VERY low.
Adjustable toe and upper control arms are always a good bet though. Then you don't have to worry.
Chernobyl is offline   Reply With Quote
Old 05-01-2005, 07:13 PM   #6
neverdone
Hmm, that makes me think if, up to a limit, both of toe and camber are inverses of each other, would it be possible to keep good toe and run massive camber. Then get rucas to fix that camber? Or will this not work?
Old 05-01-2005, 07:39 PM   #7
S14DB
AFC #1
S14DB's Avatar
Get RUCA's to fix the Camber. Toe should be fine after that(fixable with stock rods).
Old 05-01-2005, 08:12 PM   #8
98sr20ve
98sr20ve is an unknown quantity at this point
1.5 inch drop and I could not get the toe I wanted with the Camber I wanted using stock pieces. I wanted about 1.5 camber and zero toe. This is on a S13
98sr20ve is offline   Reply With Quote
Old 05-01-2005, 08:32 PM   #9
Flybert
I have fully lowered N1 PRO's tucking a little bit of tire in the rear and when my friend and I did my alignment with the laser equipment at Just Tires, we were able to get it to 0 toe with the stock arms and eccentric bolts. I always thought that it was impossible to zero it out but it did. It is the reason why I have put off buying rear toe arms for so long. This car has never been wrecked or seen any curbs either.
Old 05-02-2005, 02:26 PM   #10
neverdone
flybert - were those eccentric bolts on the toes arms or the rucas?
It appears that toe can be corrected with the stock equipment, as long as you have rucas. That brings up a question then - why replace the stock toe arms then?
Old 05-02-2005, 02:31 PM   #11
ThatGuy
Admin Asshole
ThatGuy's Avatar
Because they get worn out.
Old 05-02-2005, 02:46 PM   #12
WongFeiHung
WongFeiHung is an unknown quantity at this point
Ride height doesnt have anything to do with it directly. When your camber goes negative it will toe in. If you have alot of negative camber you may not be able to get your toe to zero with stock toe arms.
www.projectnissan.com
WongFeiHung is offline   Reply With Quote
Old 05-02-2005, 03:43 PM   #13
Flybert
I zeroed out the toe using the eccentric bolts on the toe arms of course.
As for my camber settings, I run -2.4 degrees of camber in the rear with SPL RUCAs. I'd love to have toe arms in the rear for the helm joints and for the ease of adjustability. Eventually I plan on replacing every damn rubber bushing arm on my car with that of one that has helm joints.
Old 05-02-2005, 07:46 PM   #14
neverdone
WongFeiHung you are saying then when camber is bad toe is bad, and vise versa
Chernobyl you are saying that they are inverses of each
which is it?
Also, if you can in fact get the camber you want, and use the stock or eccentricbolts to adjsut toe within reason, then why do you need toe arms for adjustabilty? Isn't their purpose (other then the joints), to allow you to adjust them so that your toe is set at zero? If you can do that with what you already have the nwhy buy them for adjustability? sorry if im coming off like an jerk, im just confused
Old 05-02-2005, 07:57 PM   #15
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
more accurate adjustment, eccentric bolts, as stated before tend to be less precise as well as since it's just thread holding it in place, it can wiggle out of adjustment and/or break.
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 05-02-2005, 08:43 PM   #16
Flybert
Adjusting eccentric bolts is a bitch. You have to be insanely steady when tightening them down or you throw off your alignment really easily. This is very noticeable when you are using laser alignment equipment.
Old 05-03-2005, 07:46 AM   #17
WongFeiHung
which is it?
What I mean is camber affects toe and vice versa.
Toe arms give you more adjustability and eliminate rubber bushings for less slop...and they look cool.
Old 05-03-2005, 02:06 PM   #18
neverdone
good toe bars sound like a great upgrade, there are good reason to buy them, but for a 2" to 2.5" inch drop will they be nesscary if I already have rucas? ANd is it nessesary to have my toe set 0 perfectly?
Old 05-03-2005, 03:05 PM   #19
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Yeah,especially while driftng, the side-load forces put strain on your bushings (all of them) and in addition, can make those ecentric bolts turn. Making every mounting joint solid and keeping the adjustment linear (screw-type adjustment of length) will be less apt to change with the forces caused by severe slip angles (drifting). Even though your toe can be set to 0 with stock arms, its 8,000,000% more likely to change after a couple of months of drifting.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 05-03-2005, 07:26 PM   #20
neverdone
I see - athough it is possible to return toe to 0 with the stock adjustment, a decent drop, and rucas, - it is a good idea to get the toe bars just for reassurance. A large drop in the front with camber correction does not affect front toe settings. Is these true?
Old 05-03-2005, 07:44 PM   #21
DoriftoSlut
It does. Adjust your tie rods.
www.pinkgodzira.com
