Old 05-16-2005, 09:38 PM   #1
AenjukuCar
AenjukuCar's Avatar
AenjukuCar is an unknown quantity at this point
Send a message via AIM to AenjukuCar
s14 S14 Gauge Cluster Lights not working and some others??
Problem #1
Well I dont have any cluster lights in my 95 240sx now at all, havent now for about a month. checked all the regular fuses, even changed the bulbs on the back of the cluster. The only fuses that i have not check are the really big ones in and out of the engine bay. I have all the warning lights are working on the cluster and light up fine. Right now the only lites that light up are the volt meter gauge, the apexi turbo timer, greddy boost controller, and the boost and water temp guages. Anybody have any other ideas on what could be up?
Problem #2
I have not had any HVAC lights, the ones that light up so you can see where the air is coming from. the little green and orange lights on them work.
Problem #3
I'm installing a autometer sport compact series oil pressure gauge and was wondering what else that i would need to install it or anything else that i need to know about it.
AenjukuCar is offline   Reply With Quote
Old 05-16-2005, 10:00 PM   #2
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
I have your problem #2 I dont really care maybe its susposed to be like that? I doubt it though
Slide Happy
chuy is offline   Reply With Quote
Old 05-17-2005, 03:36 AM   #3
nigel1
nigel1 is an unknown quantity at this point
I have problem 2 also...
if someone who knows could just chime in any time it would be cool.
+0 offset PWNS me
nigel1 is offline   Reply With Quote
Old 05-17-2005, 04:39 AM   #4
Sil-Abc
Sil-Abc's Avatar
Sil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfection
Send a message via AIM to Sil-Abc
its ur tcu. time control unit. i had this problem all the time with my s13. mines is a white little box next to the fuses in the driver side so it might be the same or different. you just need to hcange that
IM JON WAYNE ESQ.... bitch
Sil-Abc is offline   Reply With Quote
Old 05-17-2005, 08:16 AM   #5
a2low240
a2low240 is an unknown quantity at this point
Send a message via AIM to a2low240
replace the dimmer control unit and the HVAC's and gauge cluster lights should work.
Signature Exceeds Forum Limits
a2low240 is offline   Reply With Quote
Old 05-17-2005, 10:28 AM   #6
projectRDM
projectRDM's Avatar
You're both wrong.
There is no TCU on S14s.
And the dimmer switch would effect all the dash illumination, including the radio, hazard and defrost switches, cruise switch, and the auto switch for the driver window. Unless those are all out also that's not the problem.
Sounds more like a load of bulbs are out. Replace them.
FORMERLY R240NA
Old 05-17-2005, 01:59 PM   #7
AenjukuCar
AenjukuCar's Avatar
that's what i have done i replaced three bulbs on the cluster itself alone. The hazard and rear defrost works fine, those light up. It really pisses me off, cause you cant see a damn thing in their at night. I thought maybe the HVAC stuff is probably a loose wire that needs to be sured up. The Dash cluster though, i'm totally out too lunch. I'm fresh outta ideas. Now i dont know if those really big fuses control anything to the dash or not?!?
