![]() Join Date: Jun 2006
![]() Feedback Score: 20 reviews
What rear ball joint do I use?
I removed my rear lower control arms and both of the ball joint boots are ripped. I have removed the ball joints and need replacements. What ball joint can be used for the rear of an S14?
I know this has been discussed before, however none of the threads have a definative answer, just possibilities. Any help would be appreciated, thank you |
-Retired |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
There are a TON of threads out there on this, you really should have searched harder...
As for the balljoints B13 sentra front balljoints work, they're just a little tight to press in. I used a sanding drum on a rotary tool to open up the control arm a little for mine. |
Then don't use factory part numbers. Search for companies like Moog and others. S13 and s14 rear ball joints have slightly different taper so that sentra stuff might not be true in your case. This has been covered to death premie.
-Retired |
#8 | |
Since this has been covered to death, could you enlighten us and share the Moog part # for an S14 rear ball joint? |
#9 | |
![]() Join Date: Mar 2003
http://www.zilvia.net/f/tech-talk/13...-answered.html
duh. because its the moog front balljoint. there is no oem or oem replacement rear s14 balljoint.
if you've read through all these materials then you know the deal buy the front balljoint (or some other non-exact balljoint) and force them into the rear buy the entire s14 rear lower control arm from the dealership buy the hardrace or megan misnamed "rear roll center adjusters." |
#12 | |
#14 | |
#16 | |
![]() Join Date: May 2004
Trader Rating: (26)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 26 reviews
S13 = B13 SE-R front, we used MOOG Part # K9449 S14 = Same as S14 front, I used MOOG Part # K9820 |
#17 |
Why don't you use the search button. Teach a man to fish and all that lol
-Retired |
#19 |
Can anyone tell me quick as to why the sentra ball joints are being used instead of just getting the regular s13 ball joints from autozone? I recently picked up a set for the rear and the taper on the ball joint won't fit up into the spindle enough to get the nut tight enough for a cotter pin
#22 | |
thanks for the part number I'll be needing the in the future, but for now I just robbed a lower control arm with a good ball joint off of my parts car |
#24 |
S14 Front/Rear (moog K9820)
Taper low diameter 15mm Taper High diameter 18.6mm Taper length 23mm Diameter where it presses in 41mm S13 Front (Moog K9509) Taper low diameter 15.8mm Taper High diameter 18mm Taper length 19.5mm 20mm Diameter where it presses in 41mm S13 Rear (moog K9633 [b12 front]) Taper low diameter 15mm Taper High diameter 18.6mm Taper length 23mm or 23.5 Diameter where it presses in 38mm
S12 || KN13 || S13 || B16 |
