Old 05-31-2005, 06:15 PM   #1
JDMs13
JDMs13 is an unknown quantity at this point
Send a message via MSN to JDMs13
Limited Slip
If a 2 way LSD locks under acceleration and decel...when does it "slip" or bias power between the rear wheels. Is the clunking you hear from a clutch type at low speeds, the differential "slipping?"
Greg
JDMs13 is offline   Reply With Quote
Old 05-31-2005, 07:33 PM   #2
JDMs13
'Tsuuuuuuup......this to much of a newb thread for you fellows?
Old 05-31-2005, 07:37 PM   #3
Var
Var's Avatar
Send a message via AIM to Var
The lsd slips under a certain amount of torque applied to it which can vary based on the type you have. The clunking at low speeds is the diff slipping and grabbing. The clutches are packed together tight so there's no way for smooth operation at low speeds.
Hi
