Old 06-12-2005, 10:31 AM   #1
soawsome
soawsome is making a name for him/her selfsoawsome is making a name for him/her selfsoawsome is making a name for him/her self
Engine Flooding at shutdown
i just recently installed a GT2871R onto my redtop and and new greddy intake manifold and some new injectors and new MAF and ECU tune ...
I started up the car for the first time and it ran fine and i let it idle for awhile and then i shut it down. i went and started it 30 mins later and it wont start. i took out the spark plugs and they were soaked with raw fuel and so i cleaned them off and pulled the fuel pump fuse and it started up fine and then died after the fuel ran out. i then put the fune back it and i go to start it up and it starts fine agian. but when i shut it down i can hear the injectors do like one more spray after the engine is off. and then i try to start it and its flooded and i have to repeat the whole process agian unless i pull the fuse when its running and then the thing doesnt flood.
i was reading in another post with a guy with the same problem and he just fixed himself and said it was the Temp sensor.... i am not sure where the temp sensor is and if thats the problem.
please let me know any insight that could help me fix this
thanks alot
--steve--
soawsome is offline   Reply With Quote
Old 06-13-2005, 12:54 PM   #2
s14brent
s14brent is an unknown quantity at this point
i'm having the same problem right now. =\ i guess i'll go to nissan and pick it up.
s14brent is offline   Reply With Quote
Old 06-13-2005, 01:48 PM   #3
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
i post to check that all the time, cuz ive seen a couple swaps where temp sensor wirirng goes crunck or something. if wiring is bad or sensor goes bad, car sorta goes to a limp home where it dumps fuel. whether its ur sensor or wiring, id check it both. this ones stuck in my memory cuz a friend actually paid money to have a shop install gauges, speedo and misc. electrics on a conversion, and they ended up wiring gauges to temp sensor instead of temp probe. he paid like 200 bucks for a crappy job><;
ultraDorksGarage is offline   Reply With Quote
Old 06-13-2005, 08:45 PM   #4
noodl35
noodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura about
Send a message via AIM to noodl35
i would also like to know this answer, as i was configuring my adj. thermostat for my fan, i took out the plug that goes into the temp sensor. I noticed that after i put it back and started cranking, it would flood the motor. I just put the plug back in and cranked while pressing the gas down. After a couple chugs it started up. My question is, why does messing with the temp sensor do people have alot of flooding issues with the motor?
noodl35 is offline   Reply With Quote
