Old 07-12-2005, 11:31 AM   #1
evanl85
evanl85's Avatar
evanl85 is an unknown quantity at this point
What is making the rear of my car creak?
What parts could do this besides the shocks? My rear drivers side creaks at low speeds, and if I push down on the back of the car when I'm stopped. It isn't the shock (replaced less than 10k ago). What other parts do this, bushings maybe? Or is the car just old. Anyway if you have had this problem any input would be appreciated, Thanks.
evanl85 is offline   Reply With Quote
Old 07-12-2005, 01:02 PM   #2
projectRDM
projectRDM's Avatar
Aarm bushings, upright bushings, subframe bushings.
FORMERLY R240NA
Old 07-12-2005, 01:09 PM   #3
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
mine made the same noise, turned out it was the RUCA i had replaced them and somehow got a little dry in there (bushing where it bolts up) and ijust took it off and greased it up, problem solved, at least mine
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 07-12-2005, 01:11 PM   #4
evanl85
evanl85's Avatar
Is there any way to tell which bushing it might be, or do I need to get it on a lift and just look?
Old 07-12-2005, 03:12 PM   #5
TheSparo
it's just the one on the RUCA, you have to take off the wheel, and i unbolted it, not sure if i had to though, then grease it up and put it all back
