Old 07-12-2005, 01:02 PM   #1
dizbjello
dizbjello's Avatar
dizbjello is an unknown quantity at this point
SR ignitor chip testing
How do I check if my ignitor chip is good? Is there anyway of checking it with a multimeter?
dizbjello is offline   Reply With Quote
Old 07-12-2005, 05:09 PM   #2
dizbjello
dizbjello's Avatar
?? anyone know?
Old 07-12-2005, 05:11 PM   #3
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Let the car run for a minute or so then touch it, if its hot its the wrong one.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 07-12-2005, 05:40 PM   #4
dizbjello
dizbjello's Avatar
Thats the problem, my car doesn't start. I live in kansas and its kind of hard to find anyone else with a sr swap that I can check mine on. Theres no other way to check if its still good?
Old 07-12-2005, 05:43 PM   #5
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
well if you have spark wouldnt that mean it works? or dont you have spark?
mjjstang is offline   Reply With Quote
Old 07-12-2005, 05:46 PM   #6
dizbjello
dizbjello's Avatar
no spark. trying to figure out if its the ignitor chip, or ecu.
Old 07-12-2005, 05:49 PM   #7
mjjstang
and your sure that the plugs arent fouled, only reason I ask is because that is just what happened to me, and you didnt mention anything about that,
Old 07-12-2005, 05:53 PM   #8
dizbjello
dizbjello's Avatar
yea the spark plugs are fine. i took out the coilpack and put a screw driver in it and layed it on something grounded (valve cover). cranked it and no spark. i checked the wires leading up tho the coilpacks. one was ground, the other one was 12 volt. and the other one didnt read out anything.
Old 07-12-2005, 06:21 PM   #9
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
In a word, no. There is no way to check an ignitor, unless you have an electrical test bench where you can put power to it.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 07-12-2005, 06:34 PM   #10
dizbjello
dizbjello's Avatar
well that sucks. thanks anyways
Old 07-12-2005, 07:10 PM   #11
ghostchild316
ghostchild316's Avatar
ghostchild316 is an unknown quantity at this point
try taking it to an autoparts store.O'reilly or advance...
ghostchild316 is offline   Reply With Quote
Old 07-12-2005, 08:35 PM   #12
monkeyspeed
monkeyspeed is an unknown quantity at this point
yes you can, but you will need the fsm.
you have to check continuity across the leads. The fsm shows you how.
it's on page EC-202 (p.337) of the S-14 manual.
monkeyspeed is offline   Reply With Quote
Old 07-12-2005, 08:53 PM   #13
dizbjello
dizbjello's Avatar
do you have to check the continuity while the ignitor is plugged in? please help me for I do not have the FSM.
Old 07-13-2005, 07:40 AM   #14
monkeyspeed
you can find the fsm on this site or on www.zeroyon.com
the chip does not have to be plugged in to check continuity... all it does it test the circuit across the leads...
if if tests bad like mine did, you can gently crack it open and you should be able to see the broken wire. remove the sticky gel packing and apply a small solder to repair the wire... done. 10 minutes tops.
Old 07-13-2005, 12:11 PM   #15
dizbjello
dizbjello's Avatar
i check the continuity and there is none on all 4 wires. so i opened it up and there were no missing wire that i could see. could the whole thing be bad
Old 07-14-2005, 06:40 AM   #16
monkeyspeed
did you use the fsm to check or just check straight across the leads?
do you see any burn marks on the board?
