Old 11-25-2005, 08:27 PM   #1
cheez80
cheez80 is an unknown quantity at this point
SR won't start
i've searched. a lot of the stuff is really irrelevant
anyway, i did a clutch job by pulling the motor. at the same time, i relocated the wiring harness in the passenger's side fender well into the engine bay by taking it apart from the inside. i also had james at g-dimension rebuild the main engine harness.
everything's bolted back together, but the thing won't start. i've double checked all the plugs; everything seems connected and grounded, etc. the fuel pump doesn't prime anymore. when i crank it, i hear a clicking from the fuse panel area in the driver's side kick panel. i had a friend knock the starter around with a broom, but same thing happened. i also made sure the clutch interlock (is that what it's called?) is connected.
anybody have any idea what could be wrong?
cheez80 is offline   Reply With Quote
Old 11-27-2005, 10:50 PM   #2
cheez80
bizzump for shizzle. need to get the car running before friday, hopefully!
Old 11-28-2005, 07:18 AM   #3
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
maby your starter is bad.
Review Thread
bardabe is offline   Reply With Quote
Old 11-28-2005, 07:29 AM   #4
Tits952
Tits952 is an unknown quantity at this point
same thing happened to me...In my case the interlock relay by the right headlight wasnt working right. So i jumped the two wires together and it worked. Check is the power wire from the starter is properly connected too.
Tits952 is offline   Reply With Quote
Old 11-29-2005, 11:21 AM   #5
cheez80
hmm, will try. thanks
Old 11-29-2005, 11:49 AM   #6
luckie2hav3her
luckie2hav3her is an unknown quantity at this point
Send a message via AIM to luckie2hav3her
clutch pop it?? hold the clutch in, put it in 1st, push the car to gain good speed, let go of the clutch slowly then be turning the key to try and start the car
luckie2hav3her is offline   Reply With Quote
Old 12-02-2005, 06:26 PM   #7
cheez80
ok, i can get the car to crank now. the clutch interlock switch was fucked; i just jammed a paper clip into the harness. the car doesn't catch and run, though, and my fuel pressure gauge reads 0. the fuel pump doesn't prime either. i'm going to be doing more research.
thanks guys
Old 12-02-2005, 06:42 PM   #8
cotbu
cotbu's Avatar
Use a higher gear it's easier .etc 4th & 5th.
Check and see if your getting power at the pump.
Old 12-02-2005, 09:56 PM   #9
cheez80
ok, i checked to see if there's spark. there isn't. i also managed to snap the coil pack bolt too -__-
Old 12-02-2005, 11:29 PM   #10
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
its your wiring.
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
