Old 07-31-2005, 02:47 AM   #1
junkilo
junkilo's Avatar
junkilo is an unknown quantity at this point
Help with my turbo numbers
I've been running my numbers and calculations to turn my sohc turbo and I need some help with some basic questions.
I've got a t25 I think, although my first question is how do you tell the difference between a t25 and a t3 if both are unmarked? Whats the correlation between the two (and other turbos) in terms of a/r and trim? Does the turbo name, eg t4, t3, t66 etc, mean a specific trim, a/r and exducer/inducer size?
The compressor on mine has a 2" ID inlet, 2"OD outlet, .50 A/R, 56 trim wheel (44mm inducer, 60mm exducer).The turbine is a .63 A/R (it has a 063 stamped near the inlet base).
Am I nuts to try and get this to flow 20 lbs/min? Any wastegate suggestions? thanks
junkilo is offline   Reply With Quote
