![]() Join Date: Mar 2002
Yesterday I was playing Gran Tursmo 3 against one of my friends and I had my souped up RX-7 that was lowered and had like 700hp and lots of mods. I forget what map it was but I started to just drive crazy and I drifted on almost everyturn. Only problem is its hard to countersteer using the analog buttons. I need to get a steering wheel.
I also drifted in one of the liscence test (I-A final test). It is the one where you get a White Mine's Skyline GT-R R34 and you have to go through like all these full circles that get smaller and smaller the farther you get. I started using the hand break and my car started to drift and my tires smoked throughout every circle, I watched the replay over and over, it was real nice. Just fealt like sharing that with everyone. Anyone else have any GT3 drifting experiences (I Love doing rally races, you get to drift so much and looks cool with the smoke).
PROCEED Grip Gambler |
yea, I used to do that quite often, I would use an S15, S13, or an AE86 though. I acutally just stopped racing and would just drift the cars I would build. But that was months when I had a PS2, its a shame my b#itch of an ex-girlfriend decided it as a "gift" to her, so I lost all my $hit including the nice Sony Vega I had with it.... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt='
![]() Honda's are like tampons, every pussy needs one 91-S13 coupe S13koop.net coming soon... |
for some reasons i don't drift very well with most of the cars, i only can drift good with the lanevos don't know why... mind to share how you set up on those cars ?? also are the drifts you were doing a big drifts or small drifts ??
it is so hard to educate the uneducated. ![]() ![]() |
Goojob!
In GT2, I remember that liscence test...Yeah...or something similar to it...you get a WRX...you can drift in it pretty easy if you do it right. its way easier to drift with the wheel... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=' ![]()
![]() Ima newbie...! yay! Hopefully getting s14 with s15 sr20... |
Sorry, off Topic...but i just had to say...
Will, How much for the 95 S14 your selling? And is that damage on the right rear bumber, or just the light reflecting...Im too dumb and tired to tell. Reason your selling? I jus wanted to know. Btw...I been to your Type R site before...whydja sell it? i wuv TR's
- My S13 GT Drifting guide
If you want to drift , you must setup your car for drifting. Use my SILVIA K's 2000cc (J) Setup for instence, see what you think... btw this was a GT2 Built car, and can probbaly be a little different in GT3 so give it a try. SILVIA K's 2000cc (J) Okami's Team D-SIRE Drifter Lenght (mm) 4470mm Width (mm) 1690mm Height (mm) 1290mm Weight (lbs) 2526lb Displacement 1998cc Drivetrain FR Engine Type I4 DOHC Max Horsepower (rpm) 270hp / 6100rpm Max Torgue (rpm) 245-9lb-ft / 4600rpm Equipped Parts -Suspension Full Customization -Engine Balancing -Turbo Kit Stage 1 -Sports Intercooler -Racing Muffler -Peformance Chip -Port & Polish -Break Balance Controller -Sports Brakes -Twin Plate Clutch -Sports Flywheel -Carbon Driveshaft -Weight Reduction Stage 1 -Limited-Slip Full Customization -Simulation Tires(Rear) -Normal Tirers(Front) Wheels -Dunlop 2nd Wheel Set Parts Setting Suspension: F/R Spring Rate 11.5/9.0 Ride Height 89/89 Damper Bound 9/9 Damper Rebound 8/3 Camber 2.0/1.0 Toe 0/0 Stabilizer 7/6 Brake Balance 12/20 Tire Normal/Simulation Performance Tuned for Special Stage Route 5 ( 1:[email protected] ) Norm. Tires Front | Sim.Tires Rear -0-400m ( 0:14.479 ) Normal Tires -0-1000m ( 0:25.257 ) Normal Tires -Max Speed ( 177.10mph ) Normal Tires Note I encurage you drifters out there to use these settings not to copy, but to tweak and perfect. As you can see I have not messed with the LSD yet, but I soon will tweak that for longer drifting and more wheel spin. |
Nice setup dude...I'll try it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt='
AE86 POWAAAAA
they look like hell tho dude... My fav car has to be the Escudo Pikes Peak (Red and Blue) with street tires...you dont even need to fucking turn...just bash off walls and in like, 4 seconds your going 100 agian...
The easiest way to setup a car to drift in GT3 is buy LSD (fully customizable), get weight reduction only up to 2 (don't do 3 or car will be too light). Try to get as much HP out of the car (you don't have to but you can if you want). Then change your ride hieght to lowest, and change Limited Slip deceleration to almost max. That will get your rear end to slip real easily. I have read in several places that getting high traction tires for the front tires and low traction for the rear wheels, or just getting simulation tires. That will get your car to slip a lot and get your front tires to handle better. Use those settings as a guideline and then tweak it till you get the perfect settings. Keep in mind that different leves require different settings (so it helps to save and label your settings).
All my drifts were full drifts. I haven't tried drifting in my Skyline yet but it shouldn't be much difficult. Go to GameFaqs for a drifting FAQ with settings for several different cars. I honestly love the RX-7 as drifter, I got an MR2 but I need to get good settings because it spins out a lot
damn, I sold my GT3 for some DVD. I remember drifting like crazy in 86's and S15's. I tried to drift in purely stock cars with no mods in 2 player battle. You know the 86 rocks but does anyone know that it can be one of the fastest cars in the game? AND you get Takumis at the end for the last car? Uhuh. I think I need to go get that game again. *sniffle* *sniffle*
Mike |
#14 |
![]() Join Date: Feb 2002
Go get it, its only $20 at Best Buy!!! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
#16 |
Sorry it took so long to reply ,
I'm asking $2200 obo, the damage is actually on the bumper itself, so its popped in. Just wanna get rid of it, I like my S13 more and the S14 needs more work than I care to spend on it. It needs some engine work too, it idles rough. I sold the R cuz I had enough fun with it, I wanted something RWD and turbo'd. and besides enough of them are getting stolen around here to start worrying. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/butbut.gif" border="0" valign="absmiddle" alt=':but:'> -will
#17 |
another tip for those of you who don't drive stick in the game. Hold the R2 button and let the car go past redline (only works in high HP cars). I found that this shaved off some numbers in the 1/4 mile.
#18 |
drifting rx7's in real life it is tuf. very quarky rear end seems to catch at random, hard to predict. this is on a stock rx7 w/ bald tires only one i've driven. oh well it has gotta be one of the coolest cars ever damn sexy, great handling, needs like 50 more hp though.
#20 |
Here's my GT3 Drift Video, 'Gran Dorifto'... go to http://www.driftcore.com and grab it from the Videos section. I'm starting work on a sequel right now, but it probably won't be completed for a few months at least.
Some of my old drift car settings: http://www.themaille.com/hgt....um=1&21 Suspension isn't all that important in some cases. Some of my newer drift cars have stock suspension (NSX, 180sx, Vanquish). It's always a good idea to put on sim tires, full custom LSD, weight reduction, clutch/flywheel/trans, and turn ASM/TCS off.
<i><a href="http://community.webshots.com/user/bryan_h">Straightaways are for fast cars. Corners are for fast drivers</a>. <br>[ <a href="http://move.to/theMR2">1987 Super Red MR2</a> | <a href="http://home.earthlink.net/~bryan64/pics/newtoy/latenightrollabig.jpg">1985 Corolla GT-S hatch</a> ]</i> |
#21 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (BryanH @ April 17 2002,12:58)</td></tr><tr><td id="QUOTE">Here's my GT3 Drift Video, 'Gran Dorifto'... go to http://www.driftcore.com and grab it from the Videos section. I'm starting work on a sequel right now, but it probably won't be completed for a few months at least.
Some of my old drift car settings: http://www.themaille.com/hgt....um=1&21 Suspension isn't all that important in some cases. Some of my newer drift cars have stock suspension (NSX, 180sx, Vanquish). It's always a good idea to put on sim tires, full custom LSD, weight reduction, clutch/flywheel/trans, and turn ASM/TCS off.</td></tr></table><span id='postcolor'> damn that was ur video. I saw it before but never found out whose it was. Nice vid! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
#22 |
Hey you guys, I have an XBOX, and you have to check out World Rally Championship, drift heaven. Drift on raods, mud gravel and even ice. I love it. Too bad our cars are not in it, although I never unlocked all the cars. Then someone stole it from the video store. Guess I;ll have to buy it.
"stop lights timed to 55 mph are also timed to 110 mph!" http://www.geocities.com/broadwayblues34/240sx.html 92 240SX Coupe! MB clear side markers Clear bumper lights 3 inch universal muffler w/ removable tip. Strut tower bar- Front OBX SS version 2 |
