Old 04-17-2002, 05:37 PM   #1
CTL
CTL is an unknown quantity at this point
Send a message via AIM to CTL
Hey are Eibach sportlines good with kyb agx? or kyb gr2 or tockiko blues? coilovers cost a lot so whats a good setup for less than $1000? cause i seen the sportlines go for a lil less than 200 and kyb agx for 400?
CTL is offline   Reply With Quote
Old 04-17-2002, 07:36 PM   #2
Two40 SX
Two40 SX is an unknown quantity at this point
I'd go with the KYB AGX's. Simply because of the exteral shock controls. But hey, that's just me.
I put screens on my motorcycle so I can play Road Rash.
Two40 SX is offline   Reply With Quote
Old 04-17-2002, 08:31 PM   #3
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
AGX's have em love em , sportlines are good for a solid drop and stiffer setup . This should be a good setup for you.
New Video
Buy my mounts!
Old 04-18-2002, 04:05 AM   #4
allshow
allshow is an unknown quantity at this point
where can you find eibach springs for less than 200? is it online?
allshow is offline   Reply With Quote
Old 04-18-2002, 06:27 AM   #5
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
I"m in the camp that says anything over 1.5" drop (i.e., sportlines) requires a short stroke damper for maximum performance.  There are a select few springs that are stiff enough to allow you 1.5" of wheel travel... but sportlines are too soft for that much drop/that little travel.
$0.02
HippoSleek is offline   Reply With Quote
Old 04-18-2002, 09:04 AM   #6
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Hipposleek, what spring (brand/model) would you suggest then?...for a drop bigger than 1.5"<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
m
400x200
mbmbmb23 is offline   Reply With Quote
Old 04-18-2002, 10:03 AM   #7
HippoSleek
HippoSleek's Avatar
See - that's the trouble <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> . &nbsp;More than 1.5" and you run out of travel fast! &nbsp;With a very stiff linear spring you might be able to live with an AGX or a Koni Yellow and a 1.5-2" drop. &nbsp;The only ones that come to mind are kg/mm s21's (Drifting Ricer has these w/ Koni's, IIRC). &nbsp;I think there are 2-3 others out there too but I don't know who makes them. &nbsp;They've got to be really stiff though to keep from bottoming constantly. &nbsp;Either the Konis or the AGX's are strong enough to run w/ high rate springs, but after having a kidney jarring rate (even w/ only 1.5" of lowering) in my old car, I personally wouldn't do that again! &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'>
The other side of the equation is to spend more on shocks so that you could use a shorter spring. &nbsp;If you get Tokico HTS or GAB Super Strokes (about $700+/-) you can run 2" of lowering while keeping 2"+ of suspension travel. &nbsp;I know uuninja has Sportlines on HTS dampers. &nbsp;The better shocks would smooth the ride and give great performance... the only problem is they are about $200 more than Konis and almost $300 more than AGX! &nbsp;This is the best solution, but also nearly as pricey as just buying a set of full coils (which have their own problems, imho). &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/huh.gif" border="0" valign="absmiddle" alt=':huh:'>
All of this is to say there are trade offs. &nbsp;For lower $$ applications: &nbsp;If you really want the look w/o the performance, perhaps you can handle riding on bumpstops. &nbsp;If you really want the performance, you should expect that your car won't be dropped a lot. &nbsp;Of course, if you have the cash, you can get the best of both worlds &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
Old 04-19-2002, 03:41 AM   #8
wav399
wav399 is an unknown quantity at this point
So, do you think coilovers is the best of both worlds? Something that gives excellent handling and gets rid of that wheel gap on the S13 and is good for a daily driver.
wav399 is offline   Reply With Quote
Old 04-19-2002, 06:59 AM   #9
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (wav399 @ April 19 2002,04:41)</td></tr><tr><td id="QUOTE">So, do you think coilovers is the best of both worlds? Something that gives excellent handling and gets rid of that wheel gap on the S13 and is good for a daily driver.</td></tr></table><span id='postcolor'>
Oh sure... if I had an s13! &nbsp;...that's one thing I'm pissed about - no GroundControls for the s14!
Coilovers are a good choice provided 1) you live in an area of smooth roads (since the spring rates are usually quite high) and 2) you don't drive hard enough to break things (getting them serviced in Japan can mean 4 months of down time and/or stock suspension). &nbsp;The more I think about it, the more the money and rough ride are worth it. &nbsp;My only problem is #2 is a possiblity and that would suck <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/butbut.gif" border="0" valign="absmiddle" alt=':but:'>
If I had an s13, I'd run custom rate GC's (probably about 300/250 - but I don't even know what stock rates are so this is a guess based on rates of other brands) with AGXs at about 1.5-1.8" of drop (depending on the approximate corner weights). &nbsp;Without seeing the set up, I'm not sure if that drop would leave me enough travel; if not, I'd move it up a bit. &nbsp;I think this would provide every good a ride as a full coil set up, get rid of ugly wheel gap, allow replacement of broken parts in two days, and offer the ability to order different spring rates ($50 ea.) if I wanted more or less stiffness. &nbsp;I like the ability to adjust or replace things separately rather than needing a whole other $1500 system. &nbsp;My total cost for that - $400+ for the shocks and probably around $400-450 for my custom rate GCs. &nbsp;That's nearly half the cost of a full coil system which means that I could replace two shocks and buy 2 more sets of 4 springs to adjust my rates to conditions for about the same money as coils <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
If I didn't live in a city that beats the hell out of cars and wanted to go lower, I'd pick up the expensive short stroke GABs and use them. &nbsp;I'm still cheaper than entry level Tiens (that I can't use b/c I live in the land of winter). &nbsp;Plus, I can get those shocks rebuilt and revalved in the USA if/when I break them.
My final caveat is to take much of this with a grain of salt. &nbsp;Why? &nbsp;Because I beat the hell out of my car. &nbsp;Most people replace the suspension b/c they want the look or better performance. &nbsp;I am replacing mine soon b/c I have to - I have found it's limits and it is holding me back from driving faster on courses. &nbsp;I like to use something to its limits before I upgrade! &nbsp;If you are unlikely to abuse your car to the limits, I'd wager a basic spring shock or entry level coilover system would be sufficient. &nbsp;Perhaps some kg/mm D21's or even Pro Kits (most JDM springs are too hard and low for comfortable daily driving, IMHO).
Old 04-19-2002, 02:04 PM   #10
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
Hmm...
I got my AGX for $370 shipped from www.coximports.com
and I got my GC coilovers from Don for $375 + $15 (approx) s&h
total cost: $760 to my door, I did LOTS of shopping around to find that <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 04-20-2002, 11:24 AM   #11
drift freaq
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">hipposleek...Oh sure... if I had an s13! ...that's one thing I'm pissed about - no GroundControls for the s14!</td></tr></table><span id='postcolor'>
what??? They have ground controls for the S14 my buddy has them. You use Koni's . There are no Ground Controls with AGX's for the S14 but with Koni's yes.
I know the say race only but I have talked to the Ground Control guys at length . Thats how I found out that AGX's are GAB's i.e. same exactly valving and stroke,just different shaft material i.e. not as nice as the GAB but efficent .
Let you in on a secret KYB builds GABS for GAB. hahahha
Oh yeah and while we are at it Tokico HTS's for our cars are not short stroke . Alex Chang moderator for FA and 240sx.org found this out when he installed a set on his 93 coupe . He know has them up for sale.
ah but I do digress . You can get Ground Controls for S14 the spring rates will be 450 front and 250-300 rear. plus you could probably get a custom rate . Call up Ground Control and ask them.
Oh yeah hey Yoshi , let me know how your GC's and AGX's work out . I have AGX's with HKS springs and plan on changing them out to Ground Controls.
Dave
New Video
Buy my mounts!
Old 04-20-2002, 12:48 PM   #12
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (drift freaq @ April 20 2002,12:24)</td></tr><tr><td id="QUOTE">what??? They have ground controls for the S14 my buddy has them. You use Koni's . There are no Ground Controls with AGX's for the S14 but with Koni's yes.
Dave</td></tr></table><span id='postcolor'>
I've heard that there is only one set of rates for the s14 (apparently the "race" kit). &nbsp;Maybe that has changed - I will have to check that out b/c if they have started receiving other rates and lengths, I'm all over them. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/notify.gif" border="0" valign="absmiddle" alt=':notify:'>
It's no secret that KYB builds GABs. &nbsp;Look at the bodies, the knobs, the mounts. &nbsp;Everything is identical (I hadn't heard about the shaft being different). &nbsp;What is different on Hondas (and Nissans according to Don Nimi and others) is the valving. &nbsp;I don't know that I can sort the differences in valving on a Nissan, but I know people who've tested AGXs vs. GABs on Hondas (w/ machines, not seat tests) and found the valving differs.
I also agree with you about the HTS's for the s13. &nbsp;I remember that thread w/ Alex and someone else. &nbsp;The conclusion was HTS ARE short stroke for an s14, but not the s13. &nbsp;Oops &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'> &nbsp;Since we are talking about an s13, I should have recalled that specific part. &nbsp;(I'm an s14 owner and I know an s14 owner w/ them, so I didn't think about the specific s13 application).
Old 04-23-2002, 10:07 PM   #13
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
See if this site will have some good used JDM stuff. &nbsp;The price in in Australian dollars...and they probably will ship to the US.
http://www.japanesemotorsport.com.au/
and you can convert it to $$USD here
http://www.xe.com/ucc/
400x200
Old 04-24-2002, 12:08 AM   #14
misnomer
misnomer's Avatar
What springs would you recommend for 1"-1.5" drop? I was thinking AGX and Pro Kits, but even the prokits drop a bit more than the roads out here allow.
Old 04-24-2002, 12:55 AM   #15
Yoshi
Yoshi's Avatar
Misnomer,
that's the main reason I went with ground control (as horrible as that sounds for a reason)... the roads around here in the country are terrible, and i wanted no more than a 1" drop MAX, however I wanted the option to go lower, terrain permitting.
I'm pretty irritated about the installation reqs for my AGX's, it requires cutting off the spring perches, which is my current PITA!! &nbsp;I'm sure all will be well when I'm done, they go on this weekend, I'll let you all know.
Old 04-24-2002, 06:13 AM   #16
luey02
luey02 is an unknown quantity at this point
too bad you void the warrenty on the agx's if you lower the car below 1.5 inches. &nbsp;I got my GC on the way, hopefully everything works out...
Yoshi, keep me updated on that install, so I know what I'm up against.. thanks man!
K. Lu
luey02 is offline   Reply With Quote
Old 04-24-2002, 12:49 PM   #17
240S15DETE6K
240S15DETE6K is an unknown quantity at this point
With the DET motor, the front of my car sat a little higher, so I was worried that if I ordered a set of springs for a US 240SX, it would still sit a little too high in the front. &nbsp;SO, I ordered a set of Don's whiteline springs that are made for a AU model car with the DET motor. &nbsp;Right height problem solved, I hope, I haven't installed them yet. &nbsp;My question is, has anyone used these with the Koni yellow's? &nbsp;Will I be happy with this set-up? &nbsp;I should have asked you all before ordering I guess.
240S15DETE6K is offline   Reply With Quote
Old 04-24-2002, 06:27 PM   #18
misnomer
misnomer's Avatar
I s'pose I'll need to read a bit more on how coilovers work opposed to regular springs. Those seem a bit out of my price range, though. . . I'm looking more in the $200-$250 range for springs ('cause I'm poor and cheap)
Old 04-25-2002, 06:57 AM   #19
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (240S15DETE6K @ April 24 2002,1:49)</td></tr><tr><td id="QUOTE">With the DET motor, the front of my car sat a little higher, so I was worried that if I ordered a set of springs for a US 240SX, it would still sit a little too high in the front. SO, I ordered a set of Don's whiteline springs that are made for a AU model car with the DET motor. Right height problem solved, I hope, I haven't installed them yet. My question is, has anyone used these with the Koni yellow's? Will I be happy with this set-up? I should have asked you all before ordering I guess.</td></tr></table><span id='postcolor'>
I've heard those springs are a little soft compared to others. &nbsp;Very streetable, I'd imagine, but I would be a bit worried about bottoming the struts in extreme driving. &nbsp;We'll wait for your review <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
