Old 09-19-2005, 06:10 PM   #1
Team Rootbeer
Team Rootbeer's Avatar
Team Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really nice
Send a message via AIM to Team Rootbeer
Lights Out! =(
well, heres my predicament.....my radio quit working, and i pulled it out......and ab 3 days ago i re-installed it and it worked fine....so i was happy, but then my front corner lights and taillights quit working...checked the fuse and it was blown....so i replaced it and now every time i turn the lights on the fuse just blows....its the 10 amp tail light fuse on s14...what do you guys think? could it be a short or something>? how can i fix?
by a tiny fuse!!! ahhhh!
Originally Posted by hotrodv
90% of the cars posted here are stock or with original rims painted black
I'm not an asshole but is the true..
Team Rootbeer is offline   Reply With Quote
Old 09-19-2005, 06:27 PM   #2
projectRDM
projectRDM's Avatar
Pull the radio back out and fix the wire you grounded out.
FORMERLY R240NA
Old 09-19-2005, 06:56 PM   #3
Team Rootbeer
what do you mean? how do i fix that?? all the extra wires are just there, i dont think anything is grounded, and how do u fix the wire?
Old 09-19-2005, 07:27 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
if you dont know how to trouble shoot general electrical issues...you might as well find somebody who can. If anything it prolly have something to do with the dimmer wire into your radio.
CLICK HERE!!!
Old 09-19-2005, 08:06 PM   #5
pwave16
pwave16's Avatar
pwave16 is an unknown quantity at this point
I am assuming that it is an aftermarket radio. First, like they said above check all your wiring. If you have ANY wires that are not connected make sure they are insulated(capped or taped off)-no matter if they are coming from car or radio- insulate them! Most likely, again assuming that it is an aftermarket radio, the problem will be with you illumination and dimmer wire. I have seen several instances where the illumination wire(usually orange/white from aftermarket deck), a postive trigger, is tied into grounding dimmer(sometimes orange/white on factory side plug), a negative. Disconnect all orange wires, Replace fuse, test out. With these wires disconnected the radio will no longer dim with light switch, but you can without shortly for testing purposes. If you no longer have that probelm check both side of the harness and make sure you are hooking up illumination to illumination. And hopefully that solves your problem
Again all of this is assuming that this is not a factory deck. Hopefully of some assistance to you !!!
pwave16 is offline   Reply With Quote
Old 09-19-2005, 11:05 PM   #6
Team Rootbeer
yes, it is an aftermarket deck, when i put it back in and turned the lights on, i saw a little "puff" of smoke come out of the dash around the radio/cluster, so what could that mean>?
Old 09-20-2005, 12:25 AM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
lol, it means have someone else install it for you
Old 09-20-2005, 07:33 AM   #8
pwave16
pwave16's Avatar
Generally a puff of smoke anywhere means trouble , but sometimes it is minor. It is most likely you burned up the illumination circuit on your radio. Try unhooking all the illumination/dimmer wires like I said in my previous post. If you did blow the illumination output it is no big deal, just don't hook it back up and the radio will always stay bright (will not dim with headlights).
Try this and let me know what happens.
back at it again....
Old 09-20-2005, 08:08 AM   #9
TOMY
TOMY is a well-known jackass
i'm having a similar problem, but I didn't do any recent electrical things, my brake lights just went out. I change the fuse but they just blow everytime. Can anyone help here?
TOMY is offline   Reply With Quote
