![]() I was searching on ebay for an LSD rear for my s13,and i saw this...
LSD Insert Have searched a few times on this forum and others,cant seem to find anyone who has used this,what do you think? Will it work? Worth it? |
#2 | |
![]() Join Date: Dec 2004
NO, its not. Phantom = Not there.
No-There Grip. Makes sense. For that amount, you can find a decent used LSD, or VLSD. Hell, since i can tell you're going to skimp on things, weld the diff. Quote:
![]() Join Date: Aug 2003
I suggest you click on the search button....
welded diff -> 2 way lsd at all times, so no limiste slip, but locked at all time.
U13 and S13 ![]() ![]() |
Welded the diff makes it 100% locked, ie, a solid 2way.
Advantages : earlier initiation, faster cornering, knowing when it'll slip Disadvan. : understeer, chirping, and being JDM Tyte. |
2 ways can disengages removing the chirping, tire wear that welded diffs come with. But 2 way LSDs and run deep into your pockets!!
If you dont know SEARCH!!! ![]() |
It says when cornering and braking it act likes a clutch type, and under acceleration it gives power to both wheels. Sounds like a 1.5 way to me. But cheeper. From the looks of the way it was designed, itll probably wear the spider grears down. Give it a try. i
![]() Join Date: May 2002
this shit is so old
the phantom grip is a pos it WILL break under drifting or hard driving circumstances, ist been tested by regular folks, and it failed quit being cheap and either weld your diff or shell out for a real LSD (hlsd, vlsd, lsd clutch) |
buy it and see how it works. You can learn a good lesson from it. You get what you pay for and dont be cheap with stuff u put on your car. Only cheap mod that have seemed to work fine would be a welded diff.
#15 | |
![]() Join Date: Dec 2002
#16 |
You guys dont seem to understand i asked an opinion of it,no where did i say i was going to get it...and i wont weld the diff that is half assed. I said i was looking for an LSD and saw this.
#17 |
what's wrong with welded diff?
do a quick search on welded diff, and see if you like it. I rode in an S13 with welded diff, didn't feel anything awkward, other than... in reverse. hhaaa. ![]()
#18 | |
#19 |
there is no point to weld a diff... me and some freinds tried it on a Rustang(mustang) the gears will weld but the welds crack apart even from the lighest driving. we opened the diff and welded everything that touched and even welded some steel strips onto the gears... but it still cracked like crusty bread..
#20 | |
AFC #1
![]() Join Date: Oct 2003
#22 | |||
![]() Join Date: Jun 2005
educate yourself Just because you guys suck and welding doesn't mean a GOOD welded diff sucks. Quote:
Welded diff half assed? ![]() That car doesn't look very half assed, but is still rocking a welded diff. What exactly makes a welded diff half assed to you? You obviously have no clue what your talking about because you didn't even bother to do a search on phantom grip. So how would you know if welded is "half assed" EDIT: I refuse to believe that you serached. Found this on the very first page of the search. http://www.zilvia.net/f/showthread.p...t=phantom+grip Last edited by i8yourfwd; 09-27-2005 at 04:48 AM.. |
#23 |
Like what was said thousands of times before, one of the only bang for your buck mod would be a welded diff. But forget about welded. Phantom for the win!!
Get 3 or 4 of them so that you wont have to pay more shipping every time one breaks.
