Old 04-30-2002, 01:23 PM   #1
miata_man
miata_man is an unknown quantity at this point
i've been having some overheating problems. even though i bleeded out the air out of the air relief plug. my car would always overheat while its idling. is it because my condenser fan isnt working? because i noticed that fan isnt spinning at all.
miata_man is offline   Reply With Quote
Old 04-30-2002, 04:20 PM   #2
misnomer
misnomer's Avatar
You mean the A/C fan (in front of the clutch fan)? That doesn't always spin. If you're overheating, check your coolant, radiator cap, clutch fan (DON'T CUT OFF YOUR FINGERS!!! If it spins, it works <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>), oil, thermostat, water pump, and oil pump in that order (more or less)
Old 04-30-2002, 06:11 PM   #3
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
ahh, i know u said it already, but double check and make sure ALL the bubble is outta the cooling system. &nbsp;i thought mine was all out, and went out for a drive, and BAMN temperture gauge off the chart...
another thing is to make sure your water pump is working or the coolant is circulating. &nbsp;trun on your car and leave the radiator cap off, on the s13 you should see the coolant flow from passanger side to the driver side. &nbsp;i'm sure it's same for the s14 as well, or what ever u have &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
240meowth is offline   Reply With Quote
Old 05-04-2002, 01:53 AM   #4
SR20DET S14
SR20DET S14 is an unknown quantity at this point
or maybe the simplest thing to check..ur FUSE...i was having the same prob...overheating at idle...so i checked the fuse n it was blown...
but wats weird...thsi is the 2nd time in a year....
SR20DET S14 is offline   Reply With Quote
