Old 03-21-2005, 04:48 AM   #1
gsxns13guy
gsxns13guy is an unknown quantity at this point
S13 motor swap ---98 ka24de into 89 s13
ok guys so I have been doing as much research as possible about the differnces between the different KA's and have downloaded al the FSM's ect. here is the list ofparts I have and a recap as to my understanding of the swap and what is nessicary.
ok parts:
1998 ka24de with 5speed tranny, ecu engine and body harness
also dead 1992 ka24de (no oil pressure)
power steering res. with lines high and low pressure
steering rack out of a 93(supossedly needed with SR also)
also a 92 5speed ecu and engine harness (no body harness)
5speed from a 1992 (with sensors)
ok so here is my understanding please correctme if my thinking is wrong!!!!
I am going to use the cams out of the 92 motor, into the 98 motor, it is my understanding that the secondary butterfly must be pinched on a 91-92 intake plenium, but not on the later 98 ? also the water temp sensor, tps, and O2, egr and MAFS must be swapped from the 92 onto the 98, (this is if I choose to use the 92 ecu) Correct?? (basically make the 98 motor with OBDII act like OBDI)??? What if I want to run the 98 ECU it is my understanding that I will have to rewire the wipers (I can figure that out with the FSM's) is this true? are there any inherant advantages to using the OBDII, I am not planning on turboing the ka EVER. also with the automagic to 5spd it is my understanding that I must bypass the parking saftey switch to basically always be in park. and here is the kicker!!! if anyone can answer this question they get a gold star, maybee two if it is in depth :-P here is the question. How do I retain HUD with the 98 motor/ecu? is it possible. here is what I have deducted through my reading and research but have not tested. it is my understanding that the spedo sensor is responsible for the digital HUD signal soooo if I remove the spedo sensor from the current transmission( or the 92 I have) I have and fit it to the new tranny (with they retro fit?)I should in theory be able to retain the HUD( I understand that the 89-90 hud and 91-94 hud have differnet tach input? how does this affect my swap?) any insight into retaining the hud with my swap would be awesome!!! thanks guys for any KNOWLEDGE that might be passed my way I am interested in doing things correctly not half assed. PLEASE enlighten me with any and all KNOWLEDGE you fellow nissaners might have thankyou! TJ
gsxns13guy is offline   Reply With Quote
