Old 09-27-2005, 12:48 AM   #1
jedi_first_degree
jedi_first_degree's Avatar
jedi_first_degree is an unknown quantity at this point
WTT: turbo'd 200sx Ser
Like the title says i'm looking to trade my Turbo 95 200sx Ser. It has 116,xxx on the car currently. The turbo parts were put on at 113,xxx. Body has no rust what so ever. It has no dents just a few spots where its scratched.
Mods.
Engine:
Garret T25 with upgraded T28 internals
Bluebird turbo mani
370 injectors
Nismo Fpr
Walboro 255 fuel pump
SARD racing bov
Big spearco front mount i/c
g20 ecu
Greddy emanage (dyno tuned at 10psi)
jgy customs 2.5 inch down pipe and test pipe
vrs exhaust with magnaflow muffler 2.5 inch mandrel bent
Spec stage 3 six puck clutch
Suspension:
Kyb agx's
koni bump stops
motivation rear upper mounts
Ground Control coilvers
17 inch Tenzo R mach 10 rims (dark gunmetal color)
hankook k106 tires with 75% tread left
Misc:
Nismo Shift Knob
98 sentra honey comb grill
triple pillar pod with auto meter oil temp, oil pressure and boost gauges
Car dyno'd at 10psi made 227hp 229 tq. Boost can be turned up on this car to about 15 psi which should put the hp around 270 whp. I kept the boost low because it was street driven and auto x'd. The intercooler on the car is a stage 3 and is good to about 500hp. If you wanted to make more power out of this car all you would need to do is upgrade the turbo and the injectors.
Now what i'm willing to consider in trade would be: s13 with sr swap, s13 plus cash or s14 with good body. Email me for pics.
jedi_first_degree is offline   Reply With Quote
