![]() Join Date: Jun 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
fuel injector cylinder 1 still going out after replacement, help
ok ok i'm so going to cry lol
one of my fuel injectors took a shit on me, cyl 1, i check my spark plugs/plug wires i think they were fine or i just don't know how to check them, i replaced the fuel injector cause from the response from my other thread it was believed to be a fuel injector, well it was, then i replaced with a spare injector i had from my other motor, drove around for a few hours, it was fine, come back home turn the car off, chilled for about an hour, started car back up to go out, shit sounds like a dman wrx, running on 3 cylinders again, fuel injector 1 goes out or cylinder one goes otu thwatever...damn, then i replace it with another spare injector, works fine, drove around for a few hours, turned car on, shit it took another shit, assuming its the fuel injector, drive around, cause i have no other way home for miles like that, soudns liek a wrx, running 3 cylinders, and it's like it's running 4 sometimes, but it's like maybe the cylidner isn't getting enough fuel injection or whatever since it seems liek it's running normal for a split second or so, or whatever, any ideas? some bad fuel injectors? something clogging taking a shit on fuel injector 1? motor's fucked? i ono valve float? bad oil leading to so n so or i ono, i ono anything i just want to know what my problem could be, need to take car to get smogged soon, well not really just state ref, so i don't wanan be fucked more tahn i already am or could be lol..so yeah, HELP! Last edited by Indolent; 09-24-2005 at 01:31 PM.. |
![]() Join Date: Mar 2003
maybe the wiring to injector #1 is fucked.
to check a plug pull the fuel pump fuse and touch the spark plug to something metal while cranking the engine. you should see a spark. |
could o rings cause injectors to fail or not do their job? i think i remember taking one out and the o ring was chewed up, but would that cause the injector to completely mess up? or would it still be functional if i jus replaced the o rings, cause if they were messed up i would assume they would at least still be like half working jus nto as good, but not in this case..well until i get new injectors or another spare or something i'll probably be recording/video taping my car spit ridiculous flames as loud as a loud ass gunshot, lighting the whole environment white (only cool thing about this problem..lol)
if an o-ring on a injector is fucked up you will leak gas like a mofo.
when you put the injectors in, put them in very carefully so you don't crimp the o-ring. my buddy who was helping me out used some motor oil to help lube the o-ring so it would slide right in. don't forget to check your wiring for injector #1. |
how should i go about checking the wiring? last time i checked, i just plugged in the cyl 1 injector to number 2, and it worked fine, any suggestions, thanks for your help/info
![]() Join Date: Jan 2003
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! only my cylinder 1 doesnt fire at all. i too have checked injectors and coil packs. sounds exactly a wrx just like u sed..... i also have tested my coil pack and saw it sparking. it is getting fuel and spark but not firing? maybe timing? i dont understand and am in the same boat as you are. mines in an SR though...
TEAM SKIDMARKS Carbon black S13 SR Coupe |
#7 | |
![]() Join Date: Oct 2003
does it only happen when you get on the throttle to a certain amount? sounds like what my car was doing, and when I pulled a spark plug I was awarded with coolant, turns out I had a steam leak in my headgasket and a bottle of stop leak fixed it, and worked fine for a long time.
icecream, nah that wasn't my problem
oh yeah i should've mentioned, got my problem solved, check this thread for my long response http://www.zilvia.net/f/showthread.p...392#post834392 or yeah just read below lol but yeah it was my fuel injector, orange tip wasn't there to hold the o ring properly, o ring went bad (i think) it literally leaked out, didn't spray, gas was just pouring out, ran hella rich, causing nice big gunshot loud flash of white big flames haha |
ok since your problem was fixed, im gonna steal this thread
