plexiglass windows s13 coupe
anyone installed some lexan/plexiglass windows on there coupe? or hatch for that matter? i was just planning on ordering some sheets cutting them out to size and riveting them in. should be some decent weight savings.
thanks matt |
Admin Asshole
![]() Join Date: Mar 2002
The only windows you could really replace on the coupe is the 1/4 windows. Those windows are personally too small to even bother with. Fastback windows are bigger and could actually make a difference. You aren't going to get 75-100lbs of weight savings out of a coupe like that though.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
![]() Join Date: Dec 2004
Yea, and it doesn't looks as great. If you DO plan on going thru with it, if you get a hefty ticket for having it, you'll reconsider. Then again, its always nice to save weight, right?
If you go with Plexiglass, the areas where you rivet them on will crack, and spread. Sooner or later, the entire sheet will crack, and become useless. If you prefer lexan, its alot thicker. make sure you heat up the rivet areas, if not, it'll crack up a bit. It works ALOT better, but, when driving, all you'll hear is the lexan wiggling (sounds like thunder, just not as loud) from the wind that hits it. GOOOOD LUCK! |
