Old 10-20-2005, 12:22 PM   #1
sweet89s13
sweet89s13's Avatar
sweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura about
functional?
are these even functional maybe only when the lights are off or sleepy but where would you find them they were all over sport compact nationals in syracuse this yearhttp://www.zilvia.net/f/attachment.php?attachmentid=9721&stc=1
SHIFT_SLIDE
sweet89s13 is offline   Reply With Quote
Old 10-20-2005, 12:37 PM   #2
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
well seeing how your intake usually sits right there (unless you have cold air), im pretty safe to assume they are functional.. i think.
s13silady is offline   Reply With Quote
Old 10-20-2005, 05:36 PM   #3
axiomatik
axiomatik's Avatar
Considering the size of the opening, I can't see it doing much, plus it's kind of ugly. You would probably get more benefit from going sleepy-eye.
Old 10-20-2005, 07:02 PM   #4
WideS13
WideS13 is an unknown quantity at this point
I bet if you cut a hole that size in your windsheild you'd change your mind about how much air would be going through something like that. I do agree 100% that its ugly and has some cureves that dont go with an S13 at all. IMO if you want to make some kind of deal to get fresh outside ait to your filter like that, do a little duct work straight down to help air come up from under the car as it naturally wants to do anyways.
WideS13 is offline   Reply With Quote
Old 10-21-2005, 11:37 AM   #5
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
if you have a 91-93 front end you can cut a huge hole right under your air intake and it will draw air through the little vent in the front bumper under the headlight...
but really, you wont notice a difference in 5 hp
you may "think" and tell all your friends so... but no
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 10-21-2005, 11:47 AM   #6
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Of course air will go through there. That is why it was made.
The real question is; Does it produce results?
http://bhworld.wordpress.com/
Old 10-21-2005, 08:11 PM   #7
axiomatik
axiomatik's Avatar
Yeah, some air will go in there, but you have to remember that air is pouring into the engine bay through the radiator, and it doesn't have an easy way to get out, so you get a high pressure zone in the engine bay at speed. It's also a tiny slit, and it is set back away from the bumper, so it won't catch as much air as, say, a slit in the windshield. Bottom line, you'll never feel a difference.
Old 10-25-2005, 12:36 AM   #8
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
having little vents like that dont do squat, if u really would like some diffrence route some intake tubing to a hole in the bumper with the filter facing forward.. that would probably help...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
