Old 10-23-2005, 01:00 PM   #1
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
Pic request, S14 manual harness
I need an upclose picture of an S14 KA manual harness. The pic i need is of the neautral switch connector and of the 5th gear connector. I need to be able to see the wire colors on the harness so i can know wich wires the correspond to on the tranny.
thanks
rim_bender is offline   Reply With Quote
Old 10-23-2005, 07:23 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
read your FSM. also, search for manual swap and on 240sx.org or somewhere, there is a whole DIY wiring schematic that should take care of all that shit
Old 10-23-2005, 09:09 PM   #3
rim_bender
Dont think you understand
i do not have the manual harness so all the DIY guides wont help me at all,
and the two wires for each sensor are the same coloe, exactly the same color
the FSM list the colors only for the harness, not the sensors themselves.
Dont matter anymore, i found someone with a manual s14 and looked under there car.
Old 10-24-2005, 12:26 AM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
you dont use the manual harness following the DIY guides, it TELLS YOU how to wire it all up
and it doesn't matter, 'cuz as long as the circuit closes when the sensor trips you'll get signal
I understand perfectly.
Old 10-24-2005, 12:34 AM   #5
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
^there you go. thats exactly why they both are same color
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
