Old 05-02-2002, 08:10 PM   #1
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
I was wondering if I could fabricate my own oil lines for my 240SX turbo project.
Are the adapters to the oil pressure unit to the oil feed universal?
For the oil return line, I think they are universal...
So would a universal kit work, and who sells them?
rancid240 is offline   Reply With Quote
Old 05-02-2002, 08:29 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
just get braided steel lines with the proper AN fittings.  The turbine side will depend on what turbo you use, the drain fitting into the oil pan will depend on what fitting you choose to tap into the pan with.
You'll definitely need to T off the oil pressure sender, and from a FA thread regarding the size of the oil pressure sender fitting:
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">
I just measured a 1/8 NPT adapter thing I had sitting around and it had a 0.194" inner diameter. That's a little bigger than 3/16" (and, as we all now know, 3/16 = -3AN).
The oil sender is 1/8 BSPT, which is pretty close in size to 1/8 NPT (the difference is the thread pitch and the thread angle).</td></tr></table><span id='postcolor'>
AceInHole is offline   Reply With Quote
Old 05-02-2002, 08:57 PM   #3
adey
adey's Avatar
adey is an unknown quantity at this point
Why can't we all just use the metric scale (makes so much more sense) and be happy?? &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''> &nbsp; All these fractions are a PITA.
"just bigger than 3/16" sounds suspiciously close to 5mm to me. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 05-02-2002, 09:00 PM   #4
rotaryknight
rotaryknight is an unknown quantity at this point
If you're in SoCali just go to Earl's on Hawthorne. They'll make that stuff while you wait.
Daily Driver- 91 240 SX SE...S13 Blacktop
HKS FMIC, EVC IV, W/G, Racing Suction, DP, Dual Drager, springs/pillow ball mounts
Whiteline sway bars
Tokico blues
Koyo Radiator, Fluidyne fan
J30 VLSD
stock exterior.
Fun Car- 94 FD3S (TO4S). The White HKS FD in FnF......may she rest in pieces.
rotaryknight is offline   Reply With Quote
Old 05-02-2002, 09:01 PM   #5
AceInHole
Autox Technician
AceInHole's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (adey @ May 01 2002,10:57)</td></tr><tr><td id="QUOTE">Why can't we all just use the metric scale (makes so much more sense) and be happy?? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''> All these fractions are a PITA.
"just bigger than 3/16" sounds suspiciously close to 5mm to me. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'></td></tr></table><span id='postcolor'>
well, you're given the exact sender thread and a fittable fitting... i wouldn't complain <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
Old 05-02-2002, 09:02 PM   #6
rancid240
Trader Rating: (72)
i'm going to use a t3 from an 81-83 280zx, which was recommended for me to use...but wont all t3's pretty much be the same?
Old 05-02-2002, 09:05 PM   #7
rancid240
Trader Rating: (72)
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">SoCali just go to Earl's on Hawthorne</td></tr></table><span id='postcolor'>
Do they do general fabrication?
What about manifolds? &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
Old 05-02-2002, 09:12 PM   #8
rancid240
Trader Rating: (72)
heres my planned setup, i've posted it on freshalloy too:
Vortech FMU ~$150
SOHC Manifold, Ceramic coated $300
used t3 turbo ~$?
downpipe
used BOV ~$? (i am going to pick one up in japan, maybe a few extra to sell in the states <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'> )
XS Engineering intercooler with endtanks. 24.00" x 11.00" x 3"
2"-2.5" intercooler piping, made with j-bends from S&S (which would be better?)
Walbro fuel pump ~$120
uhh...other stuff, maybe that i cant remember...
also, what do i do with all the vacuum hoses that are currently connected to the air intake? Can i just put breathers on those?
Old 05-02-2002, 09:13 PM   #9
rancid240
Trader Rating: (72)
oh the intercooler is with apexi endtanks, for $450
Old 05-02-2002, 10:32 PM   #10
AceInHole
Autox Technician
AceInHole's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (rancid240 @ May 01 2002,11:12)</td></tr><tr><td id="QUOTE">also, what do i do with all the vacuum hoses that are currently connected to the air intake? Can i just put breathers on those?</td></tr></table><span id='postcolor'>
plumb them into the intake piping before the compressor, probably in between the compressor and the MAF, assuming you aren't using a blow-through setup.
Old 05-03-2002, 12:27 AM   #11
rancid240
Trader Rating: (72)
you mean the intake piping to the turbo?
sorry i am stupid
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/huh.gif" border="0" valign="absmiddle" alt=':huh:'>
Old 05-03-2002, 12:36 AM   #12
rancid240
Trader Rating: (72)
i think i got it figured...
filter-maf-pipe-vacuum lines plug here-turbo-intercooler pip-bov-intercooler-intercooler pipe-throttle body...
i think that is right <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
Old 05-05-2002, 05:31 PM   #13
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (rancid240 @ May 02 2002,11:13)</td></tr><tr><td id="QUOTE">oh the intercooler is with apexi endtanks, for $450</td></tr></table><span id='postcolor'>
where did you get the core from I want a FMIC sooooooo bad it hurts (I love the look and can run more boost) <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/inlove.gif" border="0" valign="absmiddle" alt=''>
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
