Old 10-23-2005, 05:05 AM   #1
xagna
xagna has a little shameless behavior in the past
Any one tried Steering Wheel Eliminator Bushing?
I am wondering how aluminium Steering Bushing Eliminator would improve the mundane handling feel of the stock 240sx.
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWD1V
Searched this forum and 240sx and found no posting with actual opinions about this aluminium bushing. I did find a few postings about it with some imaginations and anticipations though...
If any one has tried this, please let me know what difference these brough to you.
xagna is offline   Reply With Quote
Old 10-24-2005, 10:07 PM   #2
blitz180
blitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-known
Send a message via ICQ to blitz180 Send a message via AIM to blitz180
I put one in, but at the same time I put in solid mounts, nismo tranny mount, and poly bushings... so I'd say that contributed to the overall steering and handling feel on a car 16 years old. But through the wheel, it feels like there is alot less play in it before the car starts to react. IE if you had a 16th or and 8th of an inch travel it will mostly be gone... I think it is a good investment.
blitz180 is offline   Reply With Quote
Old 10-25-2005, 12:54 AM   #3
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
Hey what about vibration, I heard that these transmit a bit "too much" vibration from the road. Is that true or not?
smily_vigor is offline   Reply With Quote
Old 10-25-2005, 01:10 AM   #4
Nismo180
Nismo180's Avatar
Nismo180 is a well-known jackass
I was mildy confused when doing my SR swap because I don't have anything like that on my steering colum. Just one U-joint halfway down, but it's your standard U-joint no rubber to be found. 89 SE, is that not something that came on everycar or am I just blessed?
Nismo180 is offline   Reply With Quote
Old 10-25-2005, 04:04 AM   #5
Drunk Bastard
Drunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really nice
Send a message via AIM to Drunk Bastard
blitz180, have you done any other front suspension mods?? after i installed my tension rods, tension rod support bar, and strut tower bar i had ZERO slop in my steering wheel.
Drunk Bastard is offline   Reply With Quote
Old 10-25-2005, 04:46 AM   #6
smily_vigor
Can any one answer my question about the vibration felt when using this?
Old 10-25-2005, 11:22 AM   #7
SoSideways
SoSideways's Avatar
This bushing, after being installed, may transfer more vibration from the road. But so would installing coilovers, solid bushings in your suspension arms, and so would going to a larger diameter wheel and lower profile tires.
However, the trade off is probably worth more than the slight bit of vibration that you'll feel through that bushing, but it's up to you, since you're the only one that knows if it's for you or not.
Old 10-25-2005, 02:11 PM   #8
cr00k_lyn
cr00k_lyn's Avatar
cr00k_lyn is an unknown quantity at this point
Send a message via AIM to cr00k_lyn
How easy is it to install this bushing, are there any write up's on this? b/c i got one sitting in my room for awhile now.
I shatter dreams like Jordan, assault and batter your team
cr00k_lyn is offline   Reply With Quote
Old 10-26-2005, 01:20 AM   #9
Tygma
Tygma's Avatar
Tygma is making a name for him/her selfTygma is making a name for him/her self
Jspec.com says you need to pull the motor... I'm not too clear on the install though. Somebody must know
My review forum
Tygma is offline   Reply With Quote
Old 10-26-2005, 02:04 AM   #10
s14slide
s14slide's Avatar
s14slide is an unknown quantity at this point
Send a message via AIM to s14slide
might have to pull a motor on a US spec car. But it's even difficult on a JDM car where we have more room to work. The bolts are a PITA, mostly cause they've been on there since manufacture and have never come off. I've also notice, working on cars and aircraft, that any bolt that's surrounded by rubber and doesn't move for a long time tend to get stuck pretty good. Even if there's no corrosion on the bolt or nut. But these are a great mod. It felt like I was in more control at steeper angles after I put this in as a solitary mod. Still got stock mounts and tie rods/ends. It in itself is a great mod for the dollar.
= My day
s14slide is offline   Reply With Quote
Old 10-26-2005, 11:52 PM   #11
Chinoliro
Chinoliro's Avatar
Chinoliro is an unknown quantity at this point
install guide here:
http://www.driftprovision.com/dpbushinstall.doc
Chinoliro is offline   Reply With Quote
Old 10-27-2005, 12:42 AM   #12
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
not all s13s ahve that bushing, check to make sure you have it before you buy the solid one
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 10-27-2005, 12:57 AM   #13
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
All s chassis i have seen have the steering shaft damper bushing.
The best way as mentioned is with the engine out.
The second best is to do this.
1. Remove under dash cover.
2. Drop steering column.
3. unplug wiring.
4. unbolt firewall to steering shaft bracket.
5. jack up car
6. place jack stands under the frame.
7. go under and remove the steering shaft to rack coupler.
8. pull out whole steering shaft.
9. install the bushings, and reinstall.
Hope this helps ya.
blu808 is offline   Reply With Quote
