Old 11-03-2005, 02:18 PM   #1
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
s14 kouki fog questions
hi im getting in my s14 kouki fogs soon and its including the brackets and wireing and bulbs.
my questions to install the fog lights do i have to remove the front bumper to mount the brackets?
and what size bulb does teh fogs use, i wana get yellow bulbes for them.
thanks
turbo2nr is offline   Reply With Quote
Old 11-03-2005, 04:34 PM   #2
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
Im pretty sure the bulbs are H3 like most nisssan foglights
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 11-03-2005, 08:29 PM   #3
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
the bulbs are h3. Yes you need to remove your bumper to mount the lights.
All s14 have fog light wiring. its just that on the base model, they dont have the switch. You can buy the SE switch and it plugs right in. The switch is on the signal indacator/headlight switch. then plug in the fuse and you're set.
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-03-2005, 08:39 PM   #4
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
iirc, isn't it possible to install the fog lights by just taking off the bolts that hold the underbody panels onto the bumper?
Try that first, if it doesn't work, or if you don't have enough room (which would probably be the case), then remove the bumper.
TurDz is offline   Reply With Quote
Old 11-03-2005, 08:54 PM   #5
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
yes H3 for fogs , remove splash shield only, need two relays, one of the regular blue ones same as a/c relay goes in driverside kick panel the wiring is there just look for it, and an odd black relay that goes in the fuse box in the egine compartment, then lastly the switch for models equiped with fog lights, all easy plug and play. sorry no part numbers, you'll need to search as i can't find the receipt for the parts when i was doing this
and good luck finding yellow bulbs
sncs14 is offline   Reply With Quote
Old 11-03-2005, 09:41 PM   #6
projectRDM
projectRDM's Avatar
Nothing like the hue of stale urine to light up the road ahead.
FORMERLY R240NA
Old 11-03-2005, 10:36 PM   #7
SimpleS14
SimpleS14's Avatar
I bought some yellow PIAA H3 bulbs from ebay awhile back...I have yet to actually use them.
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 11-03-2005, 10:59 PM   #8
turbo2nr
turbo2nr's Avatar
thanks for all the help.
the wiring is a little confusing. i have a 97 240sx le, so if i look into where the fog lights should be the wireing should be there? or is it gona be in the wireing harness around the headlights and have to be brought down?
sorry if it sounds confusing
thanks again
Old 11-04-2005, 12:46 AM   #9
nrg
how is it confusing? did you read what others posted?
your car has the wiring, it's all hanging there unpluged. Just plug in the lights, fuse, relay, switches.
driftingisgay.com
