Old 11-18-2005, 05:22 PM   #1
sijia10358
sijia10358's Avatar
sijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfection
HELP!! gas peddle stuck.....
sometimes when i drive it..the gas peddle is stuck, i have to step on it harder to make it move....i tried to find out wats making the peddle stuck but no luck.....maybe it needs more oil on the springs......
sijia10358 is offline   Reply With Quote
Old 11-18-2005, 07:10 PM   #2
sw20>>s14
sw20>>s14's Avatar
wtf is a peddle...dubDEEfowdee...
sw20>>s14 is offline   Reply With Quote
Old 11-18-2005, 08:23 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
AHAHAHA....
translation WD-40. Apply it generously to your pedal spring, throttle plate wheel, and clean the throttle body out as well while you're at it.
Old 11-19-2005, 12:40 AM   #4
Irukandji
eh you can search!!!! this has been covered, we dont spoon feed newbies here
Old 11-19-2005, 12:49 AM   #5
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
check the screws on the throttle body
Indolent is offline   Reply With Quote
Old 11-19-2005, 03:30 AM   #6
NemeGuero
No more nissan.
NemeGuero's Avatar
what do those have to do with anything?
Old 11-19-2005, 08:34 AM   #7
Indolent
Indolent's Avatar
mine use to get a little 'sticky' i was adjusting the screw, it was pretty loose, cause i was messing with it, so when i would touch the gas it wouldn't move, it wasn't that sensitive, www.240sx.org faq, "gas pedal sticking" something like that
