Old 04-15-2005, 01:51 PM   #1
Siizzzoooo
Siizzzoooo's Avatar
Siizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really niceSiizzzoooo is just really nice
Re-Routing harnesses in the fender wells?
I figure a bunch of you guys have done it to avoid your tires from rubbing on the harnesses, so what did you do to pull it into the engine bay?
or are there other options?
2004 Honda S2000 NFR | 2007 Acura TL CBP | Project ***Coming Soon***
Siizzzoooo is offline   Reply With Quote
Old 04-15-2005, 02:21 PM   #2
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
im kinda confused by your sig, you have a s14 kouki now?
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 04-15-2005, 02:30 PM   #3
Siizzzoooo
Siizzzoooo's Avatar
yes, might be gettin another one too
Old 04-15-2005, 02:33 PM   #4
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
put it sandwiched behind the fender, way easier than rerouting through the engine bay.
papershot is offline   Reply With Quote
Old 04-15-2005, 02:36 PM   #5
95Blue240sx
yeah the koukis are a PIA to re-route. iEATrice had to cut and resolder his because the harness plug was tooo big to fit through the hole. The zenkis have it easier because the plug does fit through the hole. Good luck.
Old 04-15-2005, 02:37 PM   #6
Siizzzoooo
Siizzzoooo's Avatar
Do any of the wires need to be extended at all? or is it a matter of unplugging, then enlarge the hole, reroute it, and plug it back in?
Old 04-15-2005, 02:50 PM   #7
KOUKI KA-T
KOUKI KA-T's Avatar
KOUKI KA-T is on a distinguished road
I can tell you tomorrow. I gotta do this myself and it's on my list of to-dos for the weekend. I ordered a set of 17x9+22's and want to try and run 245's up there
My car has been sold
KOUKI KA-T is offline   Reply With Quote
Old 04-15-2005, 02:56 PM   #8
Siizzzoooo
Siizzzoooo's Avatar
sweet! I might run 225/45s if i were u
Old 04-15-2005, 03:00 PM   #9
KOUKI KA-T
KOUKI KA-T's Avatar
I shuldn't have to but if I do I'll run the meaty 225-45 azenis sports... but I'd rather roll the fenders and move the harness and fit the 245's... I know Orion and a few others run 245's up front on 17x 9's+25, I just don't know if they had to fuck with the harness or not.
Old 04-15-2005, 05:42 PM   #10
projectRDM
projectRDM's Avatar
Harness is exactly the same in size and has the same plugs for all S14s, there's no need to cut anything. It pulls through from the otuside, but you don't have to unplug a thing to move it.
All you need to do to relocate the harness is cut the OE clips, drill a few holes in the upper lip, and reattach it above the lip. Takes literally 5 minutes with the fender off.
FORMERLY R240NA
Old 04-15-2005, 06:52 PM   #11
KOUKI KA-T
KOUKI KA-T's Avatar
Saved me a headache, thanks man.
Old 04-15-2005, 07:52 PM   #12
projectRDM
projectRDM's Avatar
There's another way to really move the rearward part if you want the room, there's a triangular section of steel just below the ledge, cut it out and run the harness in it's place, that will pull it up real tight at the back and give all the clerance you'll ever need.
I might take pics tommorrow if I feel friendly.
FORMERLY R240NA
Old 04-15-2005, 07:54 PM   #13
KOUKI KA-T
KOUKI KA-T's Avatar
I will try that if I can do it without removing the fender....
Old 11-20-2005, 11:03 PM   #14
sdtouge
sdtouge can only hope to improve
were you ever able to take pics?
sdtouge is offline   Reply With Quote
Old 11-21-2005, 12:01 AM   #15
Dr.Baby
Dr.Baby's Avatar
Dr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud of
Send a message via AIM to Dr.Baby
my friends
this is how we do it usually
i cut out some like R240NA said
works fine, never had problems ever w/ this way
my car is this way. moved fuse box back to rear of car (s14)
no wiring at all really thru the fender area or up top..just wiring for motor and to headlights
Dr.Baby is offline   Reply With Quote
Old 11-21-2005, 12:15 AM   #16
BOMEX180
BOMEX180 is an unknown quantity at this point
I need to do that to my car. Tires are eating up soem of the wire covers.
BOMEX180 is offline   Reply With Quote
Old 11-21-2005, 12:53 AM   #17
chmercer
chmercer's Avatar
baby, can you give any details on moving fusebox? i want to do that. this is boxy btw.
chmercer is offline   Reply With Quote
Old 11-21-2005, 01:19 AM   #18
Dr.Baby
Dr.Baby's Avatar
actually this is dousan_pg on baby's computer
we moved everything
relocated and extended
its actually a pretty straight forward job, just takes some time to extend/shorten/make sure it works.
Old 11-21-2005, 03:09 AM   #19
NemeGuero
No more nissan.
NemeGuero's Avatar
that's a lot of wiring to move. You feel it was worth it? How many wires did you have to extend? and where did you run the loom? Pics of the fuse box in its current location?
Old 11-21-2005, 03:27 AM   #20
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
why move fuse box to the rear of the trunk? that is alot of work. moving it into the glove box/under dash area would've been more easier. btw, this is called wireless engine bay. just some names for people to remember heh.
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-21-2005, 09:33 AM   #21
95Blue240sx
^^^also key words to search.
Where would you put it under the dash? What if something went out, think it would be pain to get to it? In the trunk there is tons of room.
Old 11-21-2005, 11:15 AM   #22
Shawn_of_the_Dead
Shawn_of_the_Dead's Avatar
Shawn_of_the_Dead is on a distinguished road
glove box sounds like a winner to me. I am gonna have to search for that.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Shawn_of_the_Dead is offline   Reply With Quote
Old 11-21-2005, 12:11 PM   #23
Dousan_PG
Dousan_PG's Avatar
who said i put the fuse box in the trunk???
its behind the passenger seat in the 'cubby hole' (i have no rear interior)
no i wont put it under the dash
my friend did that, regreteed it
and i cant
roll cage. hello!
glove box? no ma'am, thast for ECU
where i put it work sperfect and doesnt interfere w/ any space
worth it? yes
how many wires. dont remember wasnt that much
pretty straightforward job. mike at garage works helped me out it was my first time
he had done it on his car and some others.
anyways. i like mine. do what you will
i have no room under dash for such nonsense
ill probably go painless kit anways. s14 is les and les on the street.
Aaron
Pink GodziRa
Old 11-21-2005, 04:08 PM   #24
NemeGuero
No more nissan.
NemeGuero's Avatar
PIIICCCSSS!!!!
Purty please?
Old 11-21-2005, 05:10 PM   #25
sdtouge
then if you want to run the wiring through the engine bay, and unplug it from the interior, is it neccesary to pull the dash? i havent gotten to check it out yet as im in the dorms and my car is at home, but this is going to be one of my thanksgiving break projects.
thanks
pics showed great details thanks
Old 11-21-2005, 06:09 PM   #26
Dousan_PG
Dousan_PG's Avatar
no pics
my car isnt that nice
see it in person
actually i would get pics if i had a digital camera...but i dont!
Aaron
Pink GodziRa
Old 11-21-2005, 10:28 PM   #27
cheez80
cheez80 is an unknown quantity at this point
yes. the wiring harness runs to your steering column and attaches to all the crap there. i just did it last week -__-
cheez80 is offline   Reply With Quote
