Old 11-22-2005, 08:24 PM   #1
c0ldasice
c0ldasice is an unknown quantity at this point
Question Removing Shifter to refill tranny fluid
I am going to be doing my transmission fluid for the first time and I want to take the shifter approach. I am going to be using this http://www.zilvia.net/installs/obxss/doc.asp as a guide to remove the shifter. I was wondering if I re-use all the stuff that is stated not to be reused and if there are steps in that guide that I should not follow considering I'm still keeping my stock shifter. Thanks for the help.
c0ldasice is offline   Reply With Quote
Old 11-22-2005, 08:39 PM   #2
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
there are only 1 or 2 clips holding the shifter down. take them off, take shifter out, fill, put clips back
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 11-22-2005, 08:49 PM   #3
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
yea its pretty simple with the stock shifter. I got the damn B&M so I have to take the whole unit out. Its a pain in the ass because I have nismo mounts and they raise the driveline up about 1/4" making the front 2 bolts VERY hard to get at.
DJPimpFlex is offline   Reply With Quote
Old 11-22-2005, 08:50 PM   #4
youngmanvr4
youngmanvr4 is making a name for him/her selfyoungmanvr4 is making a name for him/her self
You shouldn't have to replace anything. The only thing that you might want to make use is still in good condition is the inner boot on the transmission. Other then that just remove our trim and leather boot. Take the 4 screws off the plate and lift out the rubber boot. Then cut ties off lift up or remove the inner boot. Take the snap ring out and fill the tranny up. Put everything back in the order you took it out.
You dont have to take the c-ring out. Just do the steps the guide says to the snap ring then fill'r'up. I guessing you know where the hole is in the side of tranny to know how much oil to put in? If not then get a 1/2 inch drive, look on the passenger side toward the front of the tranny for a peice that you can take out with the 1/2 inch drive. Its easy to find. Make sure the car is level. Pour into the tranny about 5 1/8 pts. I would pour 5 pts in. Then let it sit for a minute to let the fluid run down in the tranny. Then pour just alittle more til fuild comes out.
youngmanvr4 is offline   Reply With Quote
Old 12-02-2005, 02:45 AM   #5
c0ldasice
Thanks a lot guys, I will probably be doing the fluid tomorrow.
Old 12-02-2005, 07:11 AM   #6
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
u can actually just take the shifter out if u have a hex key set... easy to take out... but needs a little TLC to get back in
Sfourteen
dct223 is offline   Reply With Quote
Old 12-02-2005, 12:33 PM   #7
brown eyes
brown eyes's Avatar
brown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of lightbrown eyes is a glorious beacon of light
Here's a picture that might help you:
See that drain plug? See that filler plug?
Now ask yourself, why do you want to remove the shifter and give yourself all that extra work?
brown eyes is offline   Reply With Quote
Old 12-02-2005, 03:03 PM   #8
braintumor
braintumor is an unknown quantity at this point
because its a pain in the butt to fill it up through the hole. and why not swap to a short shifter while doing the fluid?
braintumor is offline   Reply With Quote
Old 12-02-2005, 03:16 PM   #9
rps13_fastback
rps13_fastback's Avatar
rps13_fastback can only hope to improve
Send a message via AIM to rps13_fastback
it's about the same amount of work, but if you've taken the shifter off before, do it that way.
teh drain/fill plugs can be a PITA. u also need a pump to pump the new fluid in the fill hole. PITA !
rps13_fastback is offline   Reply With Quote
Old 12-02-2005, 03:27 PM   #10
samms95s14se
samms95s14se's Avatar
samms95s14se will become famous soon enoughsamms95s14se will become famous soon enoughsamms95s14se will become famous soon enoughsamms95s14se will become famous soon enough
Just fill it through the filler hole in the tranny. If your going to be under there to drain it the fill hole is right there... all you need is an $8.00 fluid pump to fill it up and you can see when it starts to over flow and come out of the hole, you can't do that filling it by the shifter. Plus to chang your gear/lsd oil you will need the pump anyways! Just remember to always loosen the filler hole before the drain plug in case you can't get it off.
samms95s14se is offline   Reply With Quote
Old 12-02-2005, 03:31 PM   #11
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
i prefer the drain plug method.
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 12-02-2005, 04:06 PM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
You mean fill plug? You have to drain it the same way, silly head. I prefer filling through top of tranny(shifter).. don't need a pump or anything.
Old 12-02-2005, 05:22 PM   #13
mrmephistopheles
mrmephistopheles's Avatar
Because you can do it while the car is on the ground, and 4 bolts and a snap ring is not alot of work.
Originally Posted by PHLIP
Old 12-02-2005, 08:01 PM   #14
samms95s14se
But you still have to lift it to drain it?? And one bolt seems easier then 4 bolts and a snap ring and console removal just to get to the shifter.
Old 12-02-2005, 08:23 PM   #15
Jeff240sx
I hate you too...
Jeff240sx's Avatar
You're forgetting the main issue during filling, is having the transmission level. If it's not level, filling it to spec is hard to do.
-Jeff
Whatup?
Old 12-02-2005, 09:06 PM   #16
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
those $8 fluid pumps SUCKASS
through the shifter is SUPER easy on my corolla, no interior, all I gotta do is move the rubber boot and pull the snap ring,
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 12-03-2005, 11:39 AM   #17
samms95s14se
-Jeff
It shouldn't be rocket science to anyone but all you do is...jack up the front and insert jackstands then jackup the rear until it's level then drain and fill. Tadaaa! I changed my tranny and rear gear oil at the same time using Redline products, I just pretreated the drain and fill bolts with some liquid wrench and 15 min later they came right off I also used a little teflon tape around all the threads because I hate leaks. The pump I used reminded me of a pump lotion bottle with out the bottle part with a long clear tube that the fluid comes out of. Hope this helps anyone reading this it's easy!
Old 12-03-2005, 11:48 AM   #18
Teb74
Teb74 is an unknown quantity at this point
Or if your really cheap you can run a piece of clear tubing from the filler hole up through where the shifter is. You only have to remove a few bolts instead of taking the whole damn shifter out, while letting gravity do the work for you.. But yes go get a pump like everyones said!
Teb74 is offline   Reply With Quote
