Old 05-09-2002, 05:30 PM   #1
aqwkmf
aqwkmf is an unknown quantity at this point
im pissed....my s13 is belching out white/grey smoke at idle....it doesn't have a bad smells smells like normal exhaust but its damn thick smoke. when reving up some it gets worse...what could it be? oil is good. coolent is good. no warning lights. heat guage is slightly below half way as usual. what could it be? arggg
aqwkmf is offline   Reply With Quote
Old 05-09-2002, 05:58 PM   #2
onebadm5
onebadm5's Avatar
onebadm5 is an unknown quantity at this point
Send a message via ICQ to onebadm5
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (aqwkmf @ May 09 2002,4:30)</td></tr><tr><td id="QUOTE">im pissed....my s13 is belching out white/grey smoke at idle....it doesn't have a bad smells smells like normal exhaust but its damn thick smoke. when reving up some it gets worse...what could it be? oil is good. coolent is good. no warning lights. heat guage is slightly below half way as usual. what could it be? arggg</td></tr></table><span id='postcolor'>
oil smoke is usually blue, and it stinks.
white smoke is probably coolant that's entering the cylinder/combustion chamber, as a result of a leaking head gasket.
if it is sweet smelling, than its coolant. good luck <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
onebadm5 is offline   Reply With Quote
Old 05-09-2002, 06:15 PM   #3
aqwkmf
woops sorry i posted in the wrong forum i was so pised..... anyway....it happend right after pumped out 1st gear... so it could be the head gasket?
Old 05-09-2002, 11:32 PM   #4
gwong
gwong is an unknown quantity at this point
I'd assume it's a bad headgasket or worse--- a warped or cracked head.
1995 KA24DET- St. Louis, MO
gwong is offline   Reply With Quote
Old 05-10-2002, 06:44 AM   #5
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
mine does the same thing but it does go away after driving it.....when i start it up it is pretty a pretty quick flowing exhuast and then i rev it before driving the smoke becomes overwhelming and when i floor it pulling out into traffic i can see smoke out of my rear view mirror...... but it does go away after driving.... so i wonder what it is also.....
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/huh.gif" border="0" valign="absmiddle" alt=':huh:'>
I am GOD!
drifterx is offline   Reply With Quote
Old 05-10-2002, 07:58 AM   #6
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
in order to find out what is really wrong here is a mandatory list that is needed to find the problem:
check compression--low or loosing compression can be from blown headgasket, worn piston rings
check spark plugs--black or white or gunky looking can be from blown head gasket, worn pistons, worn valve seals
check oil---grey color or even a milky look to it can be from a blown head gasket, water pump, timing chain cover leak
these will help u
but from past experience it is problaby a blown headgasket
jeff
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline   Reply With Quote
Old 05-10-2002, 09:33 AM   #7
aqwkmf
awww that sucks....well lucky i got a 3 month warrenty so......
what would it cost to have a head gasket fixed anyway?
Old 05-10-2002, 09:58 AM   #8
mrdirty
mrdirty is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (aqwkmf @ May 10 2002,10:33)</td></tr><tr><td id="QUOTE">awww that sucks....well lucky i got a 3 month warrenty so......
what would it cost to have a head gasket fixed anyway?</td></tr></table><span id='postcolor'>
head gasket removal and installation is pretty straight forward; I've never done the ka but have participated in a few POS vans <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
Hey, what about rusty spark plugs? I've never seen reference to it before...
mrdirty is offline   Reply With Quote
Old 05-10-2002, 02:14 PM   #9
sykikchimp
WOW addicted
sykikchimp's Avatar
a leak down test will tell you where it is leaking from.
Old 05-10-2002, 02:52 PM   #10
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
gray smoke and smells like shit means you have engine oil in the exhaust (trust me i know this, i tried to failed the smog test on my camry... well, it's smoking too much and too ovbious, so i'm not smoggin it anytime soon)
but white smoke usually means you are running lean. &nbsp;that's all i know about smoke...
240meowth is offline   Reply With Quote
Old 05-11-2002, 01:25 AM   #11
misnomer
misnomer's Avatar
Uh, yeah, what he said.
Headgaskets are cheap, 30-50 bucks. It isn't the easiest thing to install, though, so anticipate a good chunk of labor pay.
