Old 12-15-2005, 01:19 PM   #1
nigel1
nigel1 is an unknown quantity at this point
shorted my cluster lights out... wtf..
so last night I was messin around with led's and I was trying to rig up some blue ones, but I accidentally touched positive to negative and all the lights turned off. so im a little confused as to what hapened. I looked over all the fuses and they all seemed to be in tact. what could I have possibly done, because usually when wires cross the fuse pops. I know theres the possibility that I didn't notice the blown fuse, or couldn't find it. would anyone know which fuse it whould be for the interior cluster lights? thanks.
clifs notes
*wires crossed
*unknown if fuse blew or what
*cant find the blown fuse
*im going to go search some more as soon as I post up this thread...
+0 offset PWNS me
nigel1 is offline   Reply With Quote
Old 12-15-2005, 01:22 PM   #2
projectRDM
projectRDM's Avatar
Keep searching, it's a fuse. If not, pull the dimmer switch out and inspect it, then move on to the TCU.
FORMERLY R240NA
Old 12-15-2005, 03:16 PM   #3
nigel1
If you didn't notice in the sig, but I have an s14, and I guess they dont have a tCU.. I checked the dimmer switch, but it seemed to be fine. when I searched , I read that the tcu was a white box next to the fuses, unless teh tcu is another color for s14's I dont think there is one...
what to do...
all the searcing is not paying off at all.
also is it true the rear lights are connected to the same fuse as the cluster lights?
I hella need to figure this out... I work at 5:15 too
+0 offset PWNS me
Old 12-15-2005, 03:41 PM   #4
nigel1
Found the problem. the insturment cluster lights are connected to the same fuse as the tail lights. I just barely bothered to check that fuse are sure enough it was dead. problem solved.
+0 offset PWNS me
Old 12-15-2005, 04:34 PM   #5
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
yah, i was just about to say, on my s13 the instrument cluster light shares the same fuse as the parking light
240meowth is offline   Reply With Quote
Old 12-16-2005, 04:23 AM   #6
projectRDM
projectRDM's Avatar
You're fired.
FORMERLY R240NA
