Old 12-13-2005, 07:35 PM   #1
Revolver Ocelot
Revolver Ocelot's Avatar
Revolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of lightRevolver Ocelot is a glorious beacon of light
Send a message via AIM to Revolver Ocelot
Cant go online with router connected!
Another question for all you computer guys. I have a linksys router. It is a wireless-G if that matters. But anyways, when it is connected i cant seem to go online. But when i just plug the ethernet cable into the modem directly everything works fine. I tried the reset button on the back of the router to no avail. Is the router toast?
Originally Posted by R240NA
240 owners = cheap, lazy fucks. If it involves more than two bolts, they didn't do it.
Revolver Ocelot is offline   Reply With Quote
Old 12-14-2005, 12:20 AM   #2
Var
Var's Avatar
Send a message via AIM to Var
both my wireless routers kept dropping the IP. Try turning off the router, the modem, and the computer and reboot.
Hi
Old 12-14-2005, 12:35 AM   #3
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Good suggestion ^^
I bet something (wireless router or your computer) isnt configured properly. Check to make sure the wireless router is getting an IP from your cable/dsl modem. It should have a web (or USB) interface where you can check that stuff at. Then it should then be giving your computer an IP address (you should know how to check this in windows). If both of those things are happening then it's another issue and you'll have to employ ping and/or tracert commands to diagnose it further....
MELLO*SOS is offline   Reply With Quote
Old 12-14-2005, 01:58 AM   #4
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
and of none of that works, try to get into your router from your computer. The IP address of a router is usually 192.168.0.1 type that into a web browser and see if you can log into the router. If not, your computer dosn't like the router and the problem is there. If yes, than maybe your modem dosn't like the router and you configure it!
240meowth is offline   Reply With Quote
Old 12-14-2005, 08:33 AM   #5
boxjelly
boxjelly's Avatar
boxjelly is an unknown quantity at this point
Is your firmware up to date?
I'm not going to sit here and blow sunshine up your ass.
boxjelly is offline   Reply With Quote
Old 12-14-2005, 08:38 AM   #6
bp057
bp057's Avatar
bp057 is an unknown quantity at this point
Send a message via AIM to bp057 Send a message via MSN to bp057
Is it cable or DSL? If your running cable, once the router is plugged in, pull the power cord from the cable modem and wait a sec then plug back in. DHCP will need to get the mac address for the router. After that if your on xp you should be good to go after about 45 sec.
But 240meowth also has a point. 192.168.1.1 or 192.168.0.1 and no user name, just admin for password.
bp057 is offline   Reply With Quote
Old 12-14-2005, 08:36 PM   #7
TopClassGarage
TopClassGarage's Avatar
TopClassGarage is an unknown quantity at this point
Then after you get the bugs worked out, use hacked firmware like me to boost signal to 3,--- radial feet, I think its dangerous, like cancer giving, but it's not at me house it just goes to it!
TopClassGarage is offline   Reply With Quote
