Old 01-10-2006, 11:50 AM   #1
solomonandfree
solomonandfree is an unknown quantity at this point
Newbie! kill switch to the ECU?
Hi! my name is Solomon Kim. Im new here and i needed alot of help!
I drive a 1989 Nissan 240sx coupe W/SR20DET. Im trying to wire up a kill switch to my ECU for theif preventions but
I dont know which to wire to cut and put a on and off switch between it. Just wondering which one did most of you guys used?
What wires did u guys use?
How many amp on the switch?
Did u guys have to use a relay?
Thanks you guys
solomonandfree is offline   Reply With Quote
Old 01-10-2006, 12:04 PM   #2
finesses240
finesses240's Avatar
finesses240 is an unknown quantity at this point
Send a message via AIM to finesses240
why are you trying to put a kill switch on the ecu, why not just do a starter kill or ignition kill? Very east to do both just need a relay and switch. If you want I can tell you how to wire it, just PM me. Good luck
*AE86 SR20 mounts*Roll Cages (any specification)**Custom Fabrication*
finesses240 is offline   Reply With Quote
Old 01-10-2006, 12:25 PM   #3
laxplaya8513
laxplaya8513 is on a distinguished road
just pull the fuel pump fuse
laxplaya8513 is offline   Reply With Quote
Old 01-10-2006, 01:04 PM   #4
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
I would think it would be risky to wire up anything to the ecu unless it was meant for it.
jdm538 is offline   Reply With Quote
Old 01-10-2006, 07:20 PM   #5
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
that would reset the ecu everytime too...
nsn240 is offline   Reply With Quote
Old 01-11-2006, 12:41 PM   #6
Steve_S14
Steve_S14 is an unknown quantity at this point
fuel pump makes more sense
Steve_S14 is offline   Reply With Quote
Old 01-11-2006, 04:31 PM   #7
tripleb
tripleb's Avatar
tripleb is a well-known jackass
Send a message via AIM to tripleb Send a message via Yahoo to tripleb
why would you want to cut the ecu. if you put the cut off on the ignition system and the fuel pump then the car is going nowhere
" I am a firm believer in a ruling clas........espcially since i rule"
tripleb is offline   Reply With Quote
