Old 01-21-2007, 08:04 AM   #1
jkgaddis
jkgaddis is making a name for him/her selfjkgaddis is making a name for him/her self
Send a message via AIM to jkgaddis
idle doesnt want to go down
so i have a freshly swapped in sr and i start it up and..... 1500rpms. so i go through the fsm and all that jazz. im confused here, it says to check timing first but the r's must be below 1g. so i went to lower the idle and i didnt just as the fsm says there and it starts to go down as im turning the screw and then it will jump back up to like 2000rpms. im lost, timing has to be done at less than 1000 but i cant even get it there. AHHH. any help is greatly appreciated. oh yeah, i searched and found a bunch of threads on adjusting idle but no one with my exact problem.
thanks for any ideas.
I'm a zilvia criminal.... I recieved an infraction
jkgaddis is offline   Reply With Quote
Old 01-21-2007, 09:11 AM   #2
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
does the idle drop at all when the motor warms up?
ladiesman8527 is offline   Reply With Quote
Old 01-21-2007, 09:19 AM   #3
jkgaddis
nope, just stays high. im about to go over to my parents house (they have a garage, i have an apartment) and try again. i got a computer over there too though so keep ideas coming and ill post up if i get any results. THANKS
Old 01-21-2007, 09:26 AM   #4
leonb2004
leonb2004 is an unknown quantity at this point
Sounds like it definetily must be a vacuum issue. Maybe you have a line hooked up wrong, or just simply a vacuum/boost leak.
leonb2004 is offline   Reply With Quote
Old 01-21-2007, 10:53 AM   #5
IngS14
IngS14's Avatar
IngS14 is making a name for him/her selfIngS14 is making a name for him/her self
Send a message via AIM to IngS14
check your timming again.
IngS14 is offline   Reply With Quote
Old 01-21-2007, 11:52 AM   #6
jkgaddis
thought my rpm's had to be below 1000 to set timing properly. as per fsm.
def not a vacuum problem. been over the system like 9 times. retightened everything.
Old 01-21-2007, 12:56 PM   #7
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
have you tried cleaning the AICV? take it off and clean it with carb cleaner. that might help. those things DO get dirty.
also, you should set timing by lifting the valve cover as per FSM.
my leaky BOV causes idle to go all over the damn place btw. going up and down 500-900 and then going all the way up to 1500 for a while, then dropping down to 1000...etc.
I would adjust timing and clean AICV first. check you BOV too although I doubt thats the problem.
redsuns3838 is offline   Reply With Quote
Old 01-21-2007, 02:30 PM   #8
s13poop
s13poop's Avatar
s13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfections13poop is close to perfection
Send a message via AIM to s13poop
http://www.zilvia.net/f/showthread.php?t=96967
^ this thread should help
clean your IACV and your intake butterfly with intake cleaner costs $3 from your local kragen
my car had stumbling/ high idle and this smoothed it out to 700rpm
if that doesn't work (which it should)
check your vaccum lines or for a dirty MAF
good luck!
s13poop is offline   Reply With Quote
Old 01-22-2007, 06:15 AM   #9
Dream240
Dream240's Avatar
I had a similar problem with my idle and found that the small vaccumm nose that plugs into the bottom of the throttle body was clogged!!! Replaced it and bam! steady low idle.
I have a KA but I'm pretty sure you have the same or similar hose. It's a hose that helps regulate idle at closed throttle....worth a try.
